Hello everyone,
I’ve created the geometry,but I don’t know how to mesh it。
Hope you can take some time to help me solve it。
Here is my cub5 file.
model.cub5 (246.8 KB)
Hello everyone,
Hi @stupid_me,
a little decomposition is needed as we need some sweepable volumes.
open "C:/Users/user/Downloads/model.cub5"
reset vol all
webcut volume all with plane xplane offset 1712
webcut volume all with plane xplane offset 1726
webcut volume all with plane yplane offset 8
imprint vol all
We can already mesh it now. We just have to make some mesh settings and make sure that we first mesh the cylinder and the adjacent volumes. Afterwards we can mesh the side surface with the pave scheme. This will then get sweeped through along the y-axis.
surface 602 size 1
curve 1086 size 1
surface 753 size 4
volume all size 30
Volume 14 13 size 4
Volume 63 64 size 4
Curve 1124 1149 size 4
Surface 753 scheme pave
mesh curve 1086
mesh surface 602
mesh surface 753
volume 14 redistribute nodes off
volume 14 scheme Sweep source surface 602 target surface 603 sweep transform least squares
volume 14 autosmooth target on fixed imprints off smart smooth off
mesh volume 14
volume 63 redistribute nodes off
volume 63 scheme Sweep source surface 753 target surface 751 sweep transform least squares
volume 63 autosmooth target on fixed imprints off smart smooth off
mesh volume 63
volume 13 redistribute nodes off
volume 13 scheme Sweep source surface 603 target surface 613 sweep transform least squares
volume 13 autosmooth target on fixed imprints off smart smooth off
mesh volume 13
volume 64 redistribute nodes off
volume 64 scheme Sweep source surface 751 target surface 761 sweep transform least squares
volume 64 autosmooth target on fixed imprints off smart smooth off
mesh volume 64
Surface 625 637 641 651 scheme pave
mesh Surface 625 637 641 651
mesh Volume 59 60 62 61
If you need more mesh control you will have to decompose the geometry further. Also you would gain a better mesh quality if angle in the cut from the cylinder wouldn’t be so sharp.
I hope this gives you some ideas.
Thank you for taking the time to answer my questions. Your approach to meshing gave me great inspiration. Through your example, I understand how to use cubit when the geometry difference is too large. I will learn from your steps and think about how to get a more suitable grid.
Thank you again for your answer.
