How to generate Periodic Mesh?
I’m beginner of trelis.
I want to analyze axi-symmetric model, like figure 1
So, the red checked plane will be periodic condition, so, there meshes are need to be same,
In case of figure 1. This model is simple, so I can generate mesh very easy by sweep.
So each side of red checked plane’s meshs totally same. (by sweep)
But, in case of figure 2
Geometry is complicate, so I can’t use sweep.
Compare to gambit, there is a option for this periodic mesh ‘Mesh Links’ (please check attached file)
Is there similar option in the trelis? I can’t find it
Please help.
Regards,
Trelis does not have a feature similar to Mesh Links in Gambit. There might be a way to use scheme copy. Would it be possible to look at the model? Could you send me the model, either to the forum or to support@csimsoft.com?
