Hex grid interface
hi, To divide the grid between the undulating surface and the buildings above it, I need a larger grid for the surface and a smaller grid for the buildings.
https://drive.google.com/file/d/1WmJI0hUpKdWNoMzn6sZZ9t74XNYrAjT-/view?usp=sharing
https://drive.google.com/file/d/1SZQUfntYht92gEAfdEO0ATVlA8BvLC-_/view?usp=sharing
set developer commands on
set import mesh tolerance 1
set multisweep on
import stl "../building.stl" merge
import stl "../surface.stl" merge
volume 2 size 0.5
volume 2 scheme sweep source surface 11 target surface 9 13
mesh volume 2
volume 1 size 0.25
volume 1 scheme sweep source surface 2 target surface 3
mesh volume 1
draw hex all
Is there any way to connect the grid between the surface and the base of the building? Thank you for your help.
Hi @aquanaut,
could you share your files via https://transfer.coreform.com/
I don’t have access to your google drive.
https://transfer.coreform.com/cTLFtM/building.stl
https://transfer.coreform.com/2aOVUk/surface.stl
You need to imprint and merge the volumes to get a connected mesh.
After that you can already mesh the volumes together and refine the building volume afterwards.
imprint vol all
volume all size 0.5
refine hex all in volume 1 numsplit 1
