I have geometry with a blunt crack tip, model as semi-circle (quarter circle for symmetry model). I want to use a radial mesh around this blunt crack. I want the mesh to look similar to what other people are doing (see attached geo1.png) .
I understand that a square is drawn around the blunt crack tip. Then this square and area around the blunt crack is decompose to “fan” parts. These parts is then mesh using the mapping scheme (see attached geo2.png)
One way to do this is to create four sides and map the surface. In my picture, the orange surface already has four curves, so a map scheme works. For the yellow surface, I split the bottom curve at an arbitrary location to create a fourth curve so that the surface can be mapped.
Thanks for the help. Now I am trying to turn this 2-D mesh into a solid 3D. I was able to do this by using the Sweeping surface (include mesh and merge) perpendicular distance. Is there any way to control the mesh seed distribution in the 3rd direction (ie when sweeping into the 3rd direction, I want a biased slices or a specified equal intervals)?
