For the generated mesh. Block 2 is not generated:
Using ExodusII API version 8.03 and DB version 8.03 to export "cubit01.e".
Writing Exodus file: |=> | 2%WARNING: The Exodus output format cannot output elements of type UNKNOWN_ELEMENT_TYPE
Skipping block 2
Writing Exodus file: |=========================> | 20%WARNING: The model contains 52 nodes (and their attached elements)
that will not be written to the genesis file.
This may indicate a problem in element block assignments.
Writing Exodus file: |====================================================================================================================================>|100%
build3.py (5.0 KB)
