Freeze curve mesh and then perform surface mesh
Hello all,
I’m a Ph.D. student in Germany. We have recently bought 2 licenses for Cubit. So far it has been very good. However, I have a problem.
I have a cube with several spherical particles embedded in it. When I mesh the cube, I would like the same number of element on the edges. So I selected all the 12 curves/edges of the cube, set the mesh size and meshed the curves.
However, when I mesh a surface near the edge, the mesh on the curve is not respected. How can I solve this problem.
I have also sized the mesh of the surface to be equal to the size of the edge mesh size, yet it does not work.
I’m uploading a picture to show the problem as well as the geometry. Kindly help.
output.cub5 (1.2 MB)
Hello @vasukolli23,
before we start meshing this.
Do you intend to mesh the volumes in a way that the opposing sides of the cube should match?
Can you describe how the final mesh should look like?
@Norbert_Hofbauer
Exactly, that is what I want. A periodic mesh, where I can apply my periodic boundary conditions script.
Do you maybe have created the geometry with cubit? If yes, have you got the journal file?
If no, could you cut out the cube at another position.
There are some bad shaped volumes and surfaces on the sides like this one
They will definitely cause issues and produce near zero element quality.
It would be good to avoid narrow surfaces and small flat volumes directly on the sides of the cube.
Do you need a hex or a tet mesh for your solver?
@Norbert_Hofbauer
I cut the cube in another position, so that there are no bad shaped volumes and surfaces on the side. The file is attached below.
I prefer a tet mesh with quadratic elements (tetra10). Thank you in advance.
output.cub5 (831.1 KB)
If you were looking for a hex mesh then the sculpt functionaliy would be an option. There is a periodic option we could use for this.
But a tet mesh is also possible. We will make use of the python interface to get it done.
First thing is, we need to ensure that the opposing sides have the same topology. Currently they share surfaces of the same size, but the topology doesn’t match.
For this we will copy and translate the cube and imprint the opposing sides.
cubit.cmd('reset')
cubit.cmd('open "C:/Users/user/Downloads/output.cub5"')
cubit.cmd('delete mesh')
cubit.cmd('reset volume all')
cubit.cmd('display')
cubit.cmd('compress')
# first imprinting to create same topology on sides
volume_ids = cubit.parse_cubit_list("volume","all")
volume_orig = ""
for vid in volume_ids:
 cubit.cmd(f"volume {vid} copy move x 15")
 volume_orig = volume_orig + str(vid) + " "
cubit.cmd(f"imprint volume all")
volume_copy_ids = cubit.parse_cubit_list("volume","all except " + volume_orig)
volumes = ""
for vid in volume_copy_ids:
 volumes = volumes + str(vid) + " "
cubit.cmd(f"volume {volumes} move x -30")
volumes = ""
cubit.cmd(f"volume {volumes} move x 15 y 15")
volumes = ""
cubit.cmd(f"volume {volumes} move y -30")
volumes = ""
cubit.cmd(f"volume {volumes} move y 15 z 15")
volumes = ""
cubit.cmd(f"volume {volumes} move z -30")
volumes = ""
cubit.cmd(f"delete volume {volumes}")
After that, we can imprint and merge the volumes and set the mesh size for the edges from the cube.
# imprint/merge and set equal mesh size on cube edges
cubit.cmd('imprint volume all')
cubit.cmd('merge volume all')
cubit.cmd('volume all scheme tetmesh')
cubit.cmd('volume all size 0.5')
curve_size = 0.5
cubit.cmd(f"curve all with x_coord=0 and y_coord=0 size {curve_size}")
cubit.cmd(f"curve all with x_coord=0 and y_coord=15 size {curve_size}")
cubit.cmd(f"curve all with x_coord=15 and y_coord=0 size {curve_size}")
cubit.cmd(f"curve all with x_coord=15 and y_coord=15 size {curve_size}")
cubit.cmd(f"curve all with y_coord=0 and z_coord=0 size {curve_size}")
cubit.cmd(f"curve all with y_coord=0 and z_coord=15 size {curve_size}")
cubit.cmd(f"curve all with y_coord=15 and z_coord=0 size {curve_size}")
cubit.cmd(f"curve all with y_coord=15 and z_coord=15 size {curve_size}")
cubit.cmd(f"curve all with x_coord=0 and z_coord=0 size {curve_size}")
cubit.cmd(f"curve all with x_coord=0 and z_coord=15 size {curve_size}")
cubit.cmd(f"curve all with x_coord=15 and z_coord=0 size {curve_size}")
cubit.cmd(f"curve all with x_coord=15 and z_coord=15 size {curve_size}")
cubit.cmd(f"curve all with x_coord=0 and y_coord=0 scheme equal")
cubit.cmd(f"curve all with x_coord=0 and y_coord=15 scheme equal")
cubit.cmd(f"curve all with x_coord=15 and y_coord=0 scheme equal")
cubit.cmd(f"curve all with x_coord=15 and y_coord=15 scheme equal")
cubit.cmd(f"curve all with y_coord=0 and z_coord=0 scheme equal")
cubit.cmd(f"curve all with y_coord=0 and z_coord=15 scheme equal")
cubit.cmd(f"curve all with y_coord=15 and z_coord=0 scheme equal")
cubit.cmd(f"curve all with y_coord=15 and z_coord=15 scheme equal")
cubit.cmd(f"curve all with x_coord=0 and z_coord=0 scheme equal")
cubit.cmd(f"curve all with x_coord=0 and z_coord=15 scheme equal")
cubit.cmd(f"curve all with x_coord=15 and z_coord=0 scheme equal")
cubit.cmd(f"curve all with x_coord=15 and z_coord=15 scheme equal")
Now we can mesh one side and copy move the mesh on the opposite side and merge them. Afterwards we mesh the volumes.
#mesh sides and imprint/merge the mesh on the opposite side
surface_ids = cubit.parse_cubit_list("surface","all with x_coord==0")
for sid in surface_ids:
 cubit.cmd(f"mesh surface {sid}")
 cubit.cmd(f"surface {sid} copy move x 15")
cubit.cmd(f"merge surface all with x_coord=15")
cubit.cmd(f"delete body all with is_sheetbody")
surface_ids = cubit.parse_cubit_list("surface","all with y_coord==0")
 cubit.cmd(f"surface {sid} copy move y 15")
cubit.cmd(f"merge surface all with y_coord=15")
surface_ids = cubit.parse_cubit_list("surface","all with z_coord==0")
 cubit.cmd(f"surface {sid} copy move z 15")
cubit.cmd(f"merge surface all with z_coord=15")
cubit.cmd('mesh vol all')
Last thing is to create blocks and set the element type.
# creating blocks
i=0
 i=i+1
 cubit.cmd(f"block {i} add volume {vid}")
 cubit.cmd(f"block {i} element type tetra10")
Here is the whole script. You can open and play it with the journal editor.
periodic_cube.py (4.4 KB)
Thank you @Norbert_Hofbauer
It works well. I appreciate your help. :slight_smile:
@Norbert_Hofbauer
I had the opportunity to think about the problem over christmas vacation again. I have a few more questions.
Due to the large number of the elements involved, I believe it is not a smart idea to have equal element size. It is better to have mesh element sizes in proportion to the size of the spherical particles (curve mesh scheme curvature). This way I have lesser mesh elements to simulate and hence requires lesser time.
This brings me back to the same question I asked in the beginning. Why does surface mesh override the curve mesh ? How can I freeze the curve mesh and make surface mesh respect it ?
Hello again @Norbert_Hofbauer
After doing a little bit of reading the documentation and playing around. I could achieve what I wanted. The final RVE looks as follows with reasonable element size based on radius size.
The code I used for meshing is here.
# meshing edges
edge_size = 0.5
for dir in ["xy", "yz", "xz"]:
    for i, j in [[0, 0], [0, rve_size], [rve_size, 0], [rve_size, rve_size]]:
        cubit.cmd(f"curve all with {dir[0]}_coord={i} and {dir[1]}_coord={j} size {edge_size}")
        cubit.cmd(f"curve all with {dir[0]}_coord={i} and {dir[1]}_coord={j} scheme equal")
        cubit.cmd(f'mesh curve all with {dir[0]}_coord={i} and {dir[1]}_coord={j}')
# mesh faces and imprint/merge the mesh on the opposite side
cubit.cmd('set maximum arc_span 22.5')
mesh_factor = 5
for dir in ["x", "y", "z"]:
    # meshing
    surface_ids = cubit.parse_cubit_list("surface", f"with {dir}_coord==0")
    cubit.cmd(f"surface {' '.join(map(str, surface_ids))} size auto factor {mesh_factor} propagate")
    cubit.cmd(f"surface {' '.join(map(str, surface_ids))} scheme trimesh")
    cubit.cmd(f"mesh surface {' '.join(map(str, surface_ids))}")
        cubit.cmd(f"surface {sid} copy move {dir} {rve_size}")
    # imprinting
    cubit.cmd(f"merge surface all with {dir}_coord={rve_size}")
# meshing other surfaces
unmeshed_surface_ids = cubit.parse_cubit_list('surface', 'with not is_meshed')
cubit.cmd(f"surface {' '.join(map(str, unmeshed_surface_ids))} size auto factor {mesh_factor} propagate")
cubit.cmd(f"surface {' '.join(map(str, unmeshed_surface_ids))} scheme trimesh")
cubit.cmd(f"mesh surface {' '.join(map(str, unmeshed_surface_ids))}")
# volume mesh
cubit.cmd(f"volume all scheme tetmesh")
cubit.cmd(f"set tetmesher hpc on")
cubit.cmd("mesh volume all")
However, it seems to generate some elements whose volume is very less or equal to 0. How to fix the quality of these elements ? Any suggestions ?
Thanks in advance.
Hi @vasukolli23,
could you please share the whole script that you are using so that i can take a look at it. Is the .cub5 from above still the basis geometry that you are importing?
Hi @Norbert_Hofbauer
The .cub5 is generated by some random particle placement. So the basis is the same but the random particle placement makes the cub5 look different.
The whole script is here and “particles.xlsx” is in the attachment
import sys
sys.path.append("C:\Program Files\Coreform Cubit 2022.4\\bin")
import cubit
import numpy as np
import pandas as pd
import pathlib as pl
import logging
logging.basicConfig(level=logging.DEBUG, filename="console.log", filemode="w", format="%(asctime)s - [%(levelname)s] - %(message)s")
cubit.init(["cubit", "-nojournal"])
cubit.reset()
# reading the particle position file
particles_fp = pl.Path("particles.xlsx")
particles_df = pd.concat([pd.read_excel(particles_fp, sheet_name="real"), pd.read_excel(particles_fp, sheet_name="ghost")])
particles_df = particles_df.reset_index()
# creating spheres
for id, particle in particles_df.iterrows():
    if particle.x == 200.0: #  please ignore why I'm doing this
        continue
    cubit.cmd(f"create sphere radius {particle['radius']}")
    cubit.cmd(f"move volume {cubit.get_entities('volume')[-1]} location {particle.x} {particle.y} {particle.z}")
# creating epoxy
rve_size = 18.0
cubit.cmd(f"create brick x {rve_size} y {rve_size} z {rve_size}")
cubit.cmd(f"move volume {cubit.get_last_id('volume')} x {rve_size / 2.} y {rve_size / 2.} z {rve_size / 2.} include_merged")
# boolean operations
# intersection - to remove ghost spheres parts outside the cube
cubit.cmd("intersect volume all")
# remove overlap and merge
for i in cubit.get_entities("volume")[:-1]:
    cubit.cmd(f"remove overlap volume {cubit.get_entities('volume')[-1]} {i} modify volume {cubit.get_entities('volume')[-1]}")
cubit.cmd("merge volume all")
# creating blocks
cubit.cmd(f"block 1 add volume {cubit.get_entities('volume')[-1]}")
cubit.cmd(f"block 1 name Epoxy")
    cubit.cmd(f"block 2 add volume {i}")
cubit.cmd("block 2 name xSP")
cubit.cmd("block all element type tetra10")
# creating materials
cubit.cmd('create material "Epoxy" property_group "CUBIT-ABAQUS" id 1')
cubit.cmd('modify material "Epoxy" scalar_properties "MODULUS" 561 "POISSON" 0.3 "YIELD_STRENGTH" 17.17')
cubit.cmd('block 1 material "Epoxy"')
cubit.cmd('create material "xSP" property_group "CUBIT-ABAQUS" id 2')
cubit.cmd('modify material "xSP" scalar_properties "MODULUS" 20e3 "POISSON" 0.3 "YIELD_STRENGTH" 800.0')
cubit.cmd('block 2 material "xSP"')
# --------------------------- Meshing ----------------------------- #
# imprinting volumes so that we have same curves and vertices on opposite side
real_vol_limit = cubit.get_last_id("volume")
displacements = [[rve_size, 0, 0], [-2 * rve_size, 0, 0], [rve_size, rve_size, 0], [0, -2.0 * rve_size, 0], [0, rve_size, rve_size], [0, 0, -2.0 * rve_size]]
for i, displacement in enumerate(displacements):
    if i == 0:
        for vid in cubit.get_entities("volume"):
            cubit.cmd(f"volume {vid} copy move x {displacement[0]} y {displacement[1]} z {displacement[2]}")
        cubit.cmd("imprint volume all")
    else:
        for vid in range(real_vol_limit, cubit.get_last_id("volume") + 1):
            cubit.cmd(f"volume {vid} move x {displacement[0]} y {displacement[1]} z {displacement[2]}")
# deleting extra volumes
cubit.cmd(f"delete volume {' '.join(map(str, range(real_vol_limit + 1, cubit.get_last_id('volume') + 1)))}")
# imprint/merge
# meshing edges
edge_size = 0.5
cubit.cmd('set maximum arc_span 15')
mesh_factor = 6
    # meshing
    # imprinting
# volume mesh
# renumbering nodes for periodic BC script success
cubit.cmd(f"renumber node all in Volume all start_id 1 uniqueids")
# export cub5 data
cubit.cmd('save cub5 "M:\HL2\RVE_generation\cubit\perfect_bonding\geometry_pb.cub5" overwrite journal')
# export abaqus input file
cubit.cmd('export abaqus "M:\HL2\RVE_generation\cubit\perfect_bonding\geometry_pb.inp" overwrite everything')
particles.zip (18.8 KB)
The .cub5 file is in the link below as it is too large to attach.
https://drive.google.com/file/d/1w3VDxXB8J56zVEkEvmrs2veFwUDBzYP-/view?usp=sharing
I would like my periodic mesh without zero (or really small volume) elements. In case you could also check and correct other quality aspects like distortion, then the simulations run smoother. But it is secondary, 0 volume elements elimination is primary.
I really appreciate your help. Thank you.
The overall quality is good, except for the narrow spaces. You should reposition some of the spheres a bit. Some are nearly touching the boundary, so there is not really any space left to build good tets in your desired size. A smaller mesh size would also help here to improve the quality.
def MeshPart():
print("[INFO] Initializing meshing process...")
# 1) Set up and mesh the geometry-based part
cellModel.StaticLinearPerturbationStep(name='PiezoStep', previous='Initial')
compositePart = cellModel.parts['Composite Part']
meshCells = compositePart.cells
# Create empty lists to store edges in each length category
shortEdges    = []  # length < 1
mediumEdges   = []  # 1 <= length < 3
longEdges     = []  # 3 <= length <= 5
extraLongEdges = [] # length > 5.0
for edge in compositePart.edges:
    edgeLength = edge.getSize()
    if edgeLength < 1.0:
        shortEdges.append(edge)
    elif 1.0 <= edgeLength < 3.0:
        mediumEdges.append(edge)
    elif 3.0 <= edgeLength <= 5.0:
        longEdges.append(edge)
    else:
    # length > 5.0
        extraLongEdges.append(edge)
# Now seed each category with a different number of elements
if shortEdges:
    print(f'[INFO] Seeding {len(shortEdges)} edges with length < 1.0 (2 elements).')
    compositePart.seedEdgeByNumber(edges=shortEdges, number=2, constraint=FIXED)
if mediumEdges:
    print(f'[INFO] Seeding {len(mediumEdges)} edges with 1.0 ≤ length < 3.0 (5 elements).')
    compositePart.seedEdgeByNumber(edges=mediumEdges, number=4, constraint=FIXED)
if longEdges:
    print(f'[INFO] Seeding {len(longEdges)} edges with 3.0 ≤ length ≤ 5.0 (10 elements).')
    compositePart.seedEdgeByNumber(edges=longEdges, number=6, constraint=FIXED)
if extraLongEdges:
    print(f'[INFO] Seeding {len(extraLongEdges)} edges (length > 5.0) with 20 elements.')
    compositePart.seedEdgeByNumber(edges=extraLongEdges, number=20, constraint=FIXED)
compositePart.seedPart(size=seed, deviationFactor=0.5, minSizeFactor=0.3, constraint=FINER)
elementType = mesh.ElemType(elemCode=C3D4E, elemLibrary=STANDARD)
compositePart.setElementType(regions=(meshCells,), elemTypes=(elementType,))
compositePart.setMeshControls(regions=meshCells, elemShape=TET, technique=FREE)
compositePart.generateMesh(regions=(meshCells,))
# 4) Convert to Orphan Mesh for Further Processing
compositePart.PartFromMesh(name='CompositeMesh', copySets=True)
compositePart = cellModel.parts['CompositeMesh']
print("[INFO] Meshing completed and orphan mesh created.")
# 2) Remove dependent instance from assembly
if 'Composite' in cellAssembly.instances.keys():
    del cellAssembly.instances['Composite']
    print("[INFO] Removed 'Composite' instance from assembly.")
import math
# 3) Bidirectional Node Alignment on Opposite Faces (Projection)
tol = 1e-6              # Tolerance for detecting nodes on min/max faces
max_pair_distance = 0.6 # In-plane distance threshold for pairing nodes
dimensions = [
    {"dim": 0, "axis_name": "X", "face_min": 0.0, "face_max": 10.0},
    {"dim": 1, "axis_name": "Y", "face_min": 0.0, "face_max": 10.0},
    {"dim": 2, "axis_name": "Z", "face_min": 0.0, "face_max": 10.0},
projection_count = {d["axis_name"]: 0 for d in dimensions}
paired_max = {d["axis_name"]: set() for d in dimensions}
paired_min = {d["axis_name"]: set() for d in dimensions}
def in_plane_distance(coord1, coord2, dim):
    partial_sums = []
    for i in range(3):
        if i != dim:
            partial_sums.append((coord1[i] - coord2[i])**2)
    return math.sqrt(sum(partial_sums))
for d in dimensions:
    dim       = d["dim"]
    axis_name = d["axis_name"]
    face_min  = d["face_min"]
    face_max  = d["face_max"]
    # Collect face nodes
    min_nodes = [node for node in compositePart.nodes if abs(node.coordinates[dim] - face_min) < tol]
    max_nodes = [node for node in compositePart.nodes if abs(node.coordinates[dim] - face_max) < tol]
    print(f"[INFO] {axis_name} Face: Found {len(min_nodes)} min nodes (near {axis_name}={face_min}).")
    print(f"[INFO] {axis_name} Face: Found {len(max_nodes)} max nodes (near {axis_name}={face_max}).")
    # Step 1: Project max → min
    aligned_max_to_min = set()
    for nodeMax in max_nodes:
        best_distance = None
        best_nodeMin  = None
        for nodeMin in min_nodes:
            dist = in_plane_distance(nodeMax.coordinates, nodeMin.coordinates, dim)
            if best_distance is None or dist < best_distance:
                best_distance = dist
                best_nodeMin  = nodeMin
        if best_nodeMin and best_distance < max_pair_distance:
            new_coord = list(best_nodeMin.coordinates)
            new_coord[dim] = face_max
            compositePart.editNode(
                nodes=(nodeMax,),
                coordinate1=new_coord[0],
                coordinate2=new_coord[1],
                coordinate3=new_coord[2]
            aligned_max_to_min.add(nodeMax.label)
            paired_max[axis_name].add(nodeMax.label)
            paired_min[axis_name].add(best_nodeMin.label)
    projection_count[axis_name] += len(aligned_max_to_min)
    print(f"[INFO] {axis_name} Face: Projected {len(aligned_max_to_min)} max nodes onto min face.")
    # Step 2: Project min → max (only if not already paired)
    aligned_min_to_max = set()
        if nodeMin.label in paired_min[axis_name]:
            continue  # Already handled in Step 1
        best_nodeMax  = None
            if nodeMax.label in paired_max[axis_name]:
                continue
            dist = in_plane_distance(nodeMin.coordinates, nodeMax.coordinates, dim)
                best_nodeMax  = nodeMax
        if best_nodeMax and best_distance < max_pair_distance:
            new_coord = list(best_nodeMax.coordinates)
            new_coord[dim] = face_min
                nodes=(nodeMin,),
            aligned_min_to_max.add(nodeMin.label)
            paired_min[axis_name].add(nodeMin.label)
            paired_max[axis_name].add(best_nodeMax.label)
    projection_count[axis_name] += len(aligned_min_to_max)
    print(f"[INFO] {axis_name} Face: Projected {len(aligned_min_to_max)} min nodes onto max face.")
# Regenerate the composite orphan mesh to update the changes
compositePart.regenerate()
print("[INFO] Composite orphan mesh has been regenerated.")
# Re-add the orphan mesh part to the assembly
cellAssembly.Instance(name='Composite', part=compositePart)
print("[INFO] Re-added 'Composite' instance to assembly.")  could not find exact mesh on opposite faces , could you please help me to generate opposite mesh, or suggest some tips
I am using python to script mesh and model , in abaqus, so is it possible to make a model having periodic mesh i am attaching an image here ,
Hi @Abhatt,
yes, it should be possible to create a periodic mesh for this. You just need to make sure that you don’t create overlapping or touching cylinders in your brick. That would most likely cause some bad elements.
And of course you must be sure that the opposing sides of the brick are matching.
yes they are non overlapping
#!/usr/bin/env python3
gmsh_surface_to_3d_periodic_copy.py (edge-seeding + fiber-profile capture)
STEP → (fragment + heal + OPTIONAL equal partitions) → surface mesh
→ declare periodic min->max faces (±X/±Y/±Z) on dims 2/1/0 (identical nodes)
→ generate 3D tets (boundary respected) → delete 2D/1D elements
→ export orphan INP with only NODE + C3D elements
(optional) export partitioned STEP for downstream tools
import sys, os, glob, math, gmsh
STEP_PATH_DEFAULT = r"C:\temp1"
OUT_DIR_DEFAULT = r"C:\temp1"
OUT_BASENAME = “Composite Part”
Default number of equal parts along X, Y, Z (same on all axes).
EQUAL_PARTS_DEFAULT = 5
-------------------- small utils --------------------
def _set_periodic_faces(master_face, slave_face, dxyz):
dx, dy, dz = dxyz
T = [ 1,0,0,dx,
      0,1,0,dy,
      0,0,1,dz,
      0,0,0, 1 ]
gmsh.model.mesh.setPeriodic(2, [slave_face], [master_face], T)
def _safe_set(name, value):
try:
    gmsh.option.setNumber(name, value)
except Exception:
    pass
def _split_paths(spec):
for sep in (';', ',', '|'):
    if sep in spec:
        return [s.strip().strip('"') for s in spec.split(sep) if s.strip()]
return [spec]
def _gather_step_inputs(step_path, steps_flag):
c=[]
if steps_flag:
    for p in _split_paths(steps_flag):
        if os.path.isdir(p):
            c += sorted(glob.glob(os.path.join(p, "*.stp"))+
                        glob.glob(os.path.join(p, "*.step")))
        else:
            c.append(p)
else:
    if os.path.isdir(step_path):
        c = sorted(glob.glob(os.path.join(step_path, "*.stp"))+
                   glob.glob(os.path.join(step_path, "*.step")))
    else:
        c = [step_path]
seen, files=set(),[]
for p in c:
    q=os.path.abspath(p)
    if os.path.isfile(q) and q not in seen:
        seen.add(q); files.append(q)
return files
def _parse_cli(argv):
step_path   = STEP_PATH_DEFAULT
target_size = 0.3
out_dir     = OUT_DIR_DEFAULT
out_base    = OUT_BASENAME
periodic    = "xyz"   # e.g. 'x', 'yz', 'xyz'
steps_flag  = None
keep3dopt   = 0    # 0 strict boundary; 1 allow interior optimize
export_step = 0    # export partitioned STEP
parts_equal = EQUAL_PARTS_DEFAULT
pos, flags = [], {}
for a in argv[1:]:
    if a.startswith("--"):
        k,_,v=a.partition("="); flags[k]=v
    else:
        pos.append(a)
if len(pos)>=1: step_path   = pos[0]
if len(pos)>=2: target_size = float(pos[1])
if "--steps"      in flags and flags["--steps"]:      steps_flag  = flags["--steps"]
if "--outdir"     in flags and flags["--outdir"]:     out_dir     = flags["--outdir"]
if "--basename"   in flags and flags["--basename"]:   out_base    = flags["--basename"]
if "--periodic"   in flags and flags["--periodic"]:   periodic    = flags["--periodic"].lower()
if "--keep3dopt"  in flags and flags["--keep3dopt"]:  keep3dopt   = int(flags["--keep3dopt"])
if "--exportSTEP" in flags and flags["--exportSTEP"]: export_step = int(flags["--exportSTEP"])
if "--parts"      in flags and flags["--parts"]:
    try:
        parts_equal = max(1, int(flags["--parts"]))
    except Exception:
# NEW flags
return (step_path, target_size, out_dir, out_base, periodic, steps_flag,
        keep3dopt, export_step, parts_equal,
def _clean_inp_to_orphan_mesh(inp_path,
                          keep_element_prefixes=("C3D",),
                          drop_keywords=("NSET","ELSET","SURFACE")):
try:
    lines=open(inp_path,"r").readlines()
except IOError:
    return
def _is_hdr(s): return s.lstrip().startswith("*")
def _HDR(s):    return s.lstrip().upper()
drop_hdrs = tuple("*"+k.upper() for k in drop_keywords)
keep_pref = tuple(p.upper() for p in keep_element_prefixes) if keep_element_prefixes else None
out=[]; i=0
while i<len(lines):
    ln = lines[i]
    if _is_hdr(ln):
        H=_HDR(ln)
        if H.startswith(drop_hdrs):
            i+=1
            while i<len(lines) and not _is_hdr(lines[i]): i+=1
            continue
        if H.startswith("*ELEMENT") and keep_pref is not None:
            header = H.replace(" ",""); et=None
            for tok in header.split(","):
                if tok.startswith("TYPE="): et = tok[5:]; break
            if et and any(et.startswith(p) for p in keep_pref):
                out.append(lines[i]); i+=1
            else:
                i+=1
            continue
        out.append(ln); i+=1
        if H.startswith("*NODE"):
        continue
try:
    open(inp_path,"w").writelines(out)
except IOError:
    pass
---------- geometry helpers ----------
def _bb(dim, tag):
x0,y0,z0,x1,y1,z1 = gmsh.model.getBoundingBox(dim, tag)
return (0.5*(x0+x1), 0.5*(y0+y1), 0.5*(z0+z1)), (x1-x0, y1-y0, z1-z0)
def _edges_of_face(face_tag):
return [t for (d,t) in gmsh.model.getBoundary([(2,face_tag)], oriented=False, recursive=False) if d==1]
def _face_pairs_by_axis(axis, bbox, h):
x0,y0,z0,x1,y1,z1 = bbox
gmin = (x0,y0,z0)[axis]; gmax = (x1,y1,z1)[axis]
span_tol = max(0.25*h, 1e-9)
pos_tol  = max(0.10*h, 1e-9)
faces    = gmsh.model.getEntities(2)
mins, maxs = [], []
for _, s in faces:
    (cx,cy,cz), (sx,sy,sz) = _bb(2, s)
    if (sx,sy,sz)[axis] > span_tol:
        continue
    if abs((cx,cy,cz)[axis] - gmin) <= pos_tol: mins.append(s)
    elif abs((cx,cy,cz)[axis] - gmax) <= pos_tol: maxs.append(s)
if axis==0: key=lambda s: (_bb(2,s)[0][1], _bb(2,s)[0][2])
elif axis==1: key=lambda s: (_bb(2,s)[0][0], _bb(2,s)[0][2])
else:         key=lambda s: (_bb(2,s)[0][0], _bb(2,s)[0][1])
mins.sort(key=key); maxs.sort(key=key)
return mins, maxs
---------- periodic helpers ----------
def _sorted_edges_of_face(face_tag, axis):
edges = _edges_of_face(face_tag)
def _key(e):
    (cx,cy,cz), _ = _bb(1, e)
    if axis == 0:  return (cy, cz)
    if axis == 1:  return (cx, cz)
    return (cx, cy)
return sorted(edges, key=_key)
def _points_of_edge(edge_tag):
bnd = gmsh.model.getBoundary([(1, edge_tag)], oriented=False, recursive=False)
return [t for (d,t) in bnd if d == 0]
def _set_periodic_all(master_face, slave_face, dxyz, axis):
dx,dy,dz = dxyz
T = [1,0,0,dx, 0,1,0,dy, 0,0,1,dz, 0,0,0,1]
m_edges = _sorted_edges_of_face(master_face, axis)
s_edges = _sorted_edges_of_face(slave_face,  axis)
if len(m_edges) != len(s_edges):
    raise RuntimeError("Edge count mismatch on faces %d vs %d" % (master_face, slave_face))
for me, se in zip(m_edges, s_edges):
    gmsh.model.mesh.setPeriodic(1, [se], [me], T)
    m_pts = sorted(_points_of_edge(me))
    s_pts = sorted(_points_of_edge(se))
    n = min(len(m_pts), len(s_pts))
    for mp, sp in zip(m_pts[:n], s_pts[:n]):
        gmsh.model.mesh.setPeriodic(0, [sp], [mp], T)
def _copy_all_opposite_faces(axes=‘xyz’):
x0,y0,z0,x1,y1,z1 = gmsh.model.getBoundingBox(-1,-1)
bbox = (x0,y0,z0,x1,y1,z1)
Lx,Ly,Lz = x1-x0, y1-y0, z1-z0
base = min(max(Lx,1e-12), max(Ly,1e-12), max(Lz,1e-12))
h = max(base/25.0, 1e-4)
gmsh.model.occ.removeAllDuplicates()
gmsh.model.occ.synchronize()
axes = axes.lower().replace('all','xyz')
axes = ''.join(ch for ch in axes if ch in 'xyz')
total = 0
for ax, dxyz in zip((0,1,2), [(Lx,0,0),(0,Ly,0),(0,0,Lz)]):
    if 'xyz'[ax] not in axes:
        continue
    mins, maxs = _face_pairs_by_axis(ax, bbox, h)
    if len(mins) != len(maxs):
        raise RuntimeError("Opposite face count mismatch on axis %s: %d vs %d"
                           % ('xyz'[ax], len(mins), len(maxs)))
    for mFace, sFace in zip(mins, maxs):
        _set_periodic_all(mFace, sFace, dxyz, axis=ax)
        total += 1
return total
def _prune_tiny_volumes(min_span=None):
Lx,Ly,Lz = max(x1-x0,1e-12), max(y1-y0,1e-12), max(z1-z0,1e-12)
if min_span is None:
    min_span = 1e-4 * min(Lx, Ly, Lz)
tiny = []
for _, v in gmsh.model.getEntities(3):
    a,b,c,d,e,f = gmsh.model.getBoundingBox(3, v)
    if min(d-a, e-b, f-c) < min_span:
        tiny.append((3, v))
if tiny:
    gmsh.model.occ.remove(tiny)
    print("[PRUNE] Removed %d tiny volumes (min_span=%.3g)" % (len(tiny), min_span))
def _remove_surface_and_edge_elements():
for dim in (2,1):
    for _, tag in gmsh.model.getEntities(dim):
        eTypes, eTags, _ = gmsh.model.mesh.getElements(dim, tag)
        if eTypes:
            allET = [t for arr in eTags for t in arr]
            if allET:
                gmsh.model.mesh.removeElements(dim, tag, allET)
---------------- Equal partitions + fragment ----------------
def _equal_internal_planes(x0, x1, parts):
if parts is None or parts <= 1:
    return []
L = max(x1 - x0, 1e-12)
return [x0 + (i * L) / float(parts) for i in range(1, parts)]
def _add_equal_partitions_and_fragment(bbox, parts_equal):
if parts_equal is None or parts_equal <= 1:
    return 0
Lx, Ly, Lz = x1-x0, y1-y0, z1-z0
pad = 1e-6 + 0.02*max(Lx,Ly,Lz)
xs = _equal_internal_planes(x0, x1, parts_equal)
ys = _equal_internal_planes(y0, y1, parts_equal)
zs = _equal_internal_planes(z0, z1, parts_equal)
epsX = 1e-6 * max(Lx, 1.0)
epsY = 1e-6 * max(Ly, 1.0)
epsZ = 1e-6 * max(Lz, 1.0)
xs = [u for u in xs if (x0 + epsX) < u < (x1 - epsX)]
ys = [u for u in ys if (y0 + epsY) < u < (y1 - epsY)]
zs = [u for u in zs if (z0 + epsZ) < u < (z1 - epsZ)]
if not (xs or ys or zs):
    return 0
def _rectYZ_at_x(xc):
    p1 = gmsh.model.occ.addPoint(xc, y0-pad, z0-pad)
    p2 = gmsh.model.occ.addPoint(xc, y1+pad, z0-pad)
    p3 = gmsh.model.occ.addPoint(xc, y1+pad, z1+pad)
    p4 = gmsh.model.occ.addPoint(xc, y0-pad, z1+pad)
    l1 = gmsh.model.occ.addLine(p1,p2); l2 = gmsh.model.occ.addLine(p2,p3)
    l3 = gmsh.model.occ.addLine(p3,p4); l4 = gmsh.model.occ.addLine(p4,p1)
    cl = gmsh.model.occ.addCurveLoop([l1,l2,l3,l4])
    return gmsh.model.occ.addPlaneSurface([cl])
def _rectXZ_at_y(yc):
    p1 = gmsh.model.occ.addPoint(x0-pad, yc, z0-pad)
    p2 = gmsh.model.occ.addPoint(x1+pad, yc, z0-pad)
    p3 = gmsh.model.occ.addPoint(x1+pad, yc, z1+pad)
    p4 = gmsh.model.occ.addPoint(x0-pad, yc, z1+pad)
def _rectXY_at_z(zc):
    p1 = gmsh.model.occ.addPoint(x0-pad, y0-pad, zc)
    p2 = gmsh.model.occ.addPoint(x1+pad, y0-pad, zc)
    p3 = gmsh.model.occ.addPoint(x1+pad, y1+pad, zc)
    p4 = gmsh.model.occ.addPoint(x0-pad, y1+pad, zc)
cut_surfs=[]
for xc in xs: cut_surfs.append((2,_rectYZ_at_x(xc)))
for yc in ys: cut_surfs.append((2,_rectXZ_at_y(yc)))
for zc in zs: cut_surfs.append((2,_rectXY_at_z(zc)))
vols = [(3,v) for (_,v) in gmsh.model.getEntities(3)]
try:
    out,_ = gmsh.model.occ.fragment(vols, cut_surfs)
    cnt = len([1 for d,_ in out if d==3])
finally:
    try:
    finally:
_prune_tiny_volumes()
return cnt
------------------------------ main ------------------------------
def main():
 ) = _parse_cli(sys.argv)
step_files = _gather_step_inputs(step_path, steps_flag)
if not step_files: raise RuntimeError("No STEP files found.")
if not os.path.isdir(out_dir): os.makedirs(out_dir)
OUT_MSH  = os.path.join(out_dir, out_base + ".msh")
OUT_INP  = os.path.join(out_dir, out_base + ".inp")
OUT_STP  = os.path.join(out_dir, out_base + "_partitioned.step")
gmsh.initialize()
gmsh.option.setNumber("General.Terminal", 1)
gmsh.model.add("STEPModel")
gmsh.logger.start()
print("[IMPORT] STEP files:")
for p in step_files:
    print("  -", p)
    gmsh.model.occ.importShapes(p)
vols = gmsh.model.getEntities(3)
if not vols: raise RuntimeError("No 3D volumes in geometry.")
# imprint touching faces + heal
try:
    gmsh.model.occ.fragment(vols, [])
finally:
    try:
    finally:
# bbox + default h
xmin,ymin,zmin,xmax,ymax,zmax = gmsh.model.getBoundingBox(-1,-1)
Lx,Ly,Lz = xmax-xmin, ymax-ymin, zmax-zmin
if target_size is None:
    target_size = max(base/25.0, 1e-4)
# OPTIONAL: add equal partitions (for conformal sub-regions)
nvol_after = _add_equal_partitions_and_fragment((xmin,ymin,zmin,xmax,ymax,zmax), parts_equal)
if nvol_after:
    print("[PARTITION] Equal parts/axis:", parts_equal, "| total 3D entities now:", nvol_after)
# ---------- 2D boundary settings (deterministic) ----------
pts = gmsh.model.getEntities(0)
if pts: gmsh.model.mesh.setSize(pts, target_size)
# Turn ON curvature-based sizing (for round fibers) and enforce elems per 2*pi
_safe_set("Mesh.CharacteristicLengthFromCurvature", 1)
_safe_set("Mesh.MinimumElementsPerTwoPi", 16)    # default 24; bump with --m2pi
_safe_set("Mesh.Algorithm", 5)                     # 2D Delaunay
_safe_set("Mesh.Optimize", 0)
_safe_set("Mesh.Smoothing", 0)
_safe_set("Mesh.RecombineAll", 0)
# ---------- Declare periodicity (faces+edges+points) then generate 2D ----------
if periodic:
    try:
        n_pairs = _copy_all_opposite_faces(periodic)
        if n_pairs == 0:
            print("[WARN] No opposite planar face pairs found to declare periodicity.")
    except RuntimeError as e:
        print("[PERIODIC ERROR]", str(e))
        # fall back to non-periodic if pairing fails
# Optional background field to make elements even smaller near *all* curves
gmsh.model.mesh.generate(2)
# ---------- 3D fill (Tet4) ----------
_safe_set("Mesh.ElementOrder", 1)
_safe_set("Mesh.SecondOrderLinear", 0)
_safe_set("Mesh.Algorithm3D", 4)
if keep3dopt:
    _safe_set("Mesh.OptimizeNetgen", 0)
else:
gmsh.model.mesh.generate(3)
# remove 2D/1D so only 3D solids remain
# Export meshes
_safe_set("Mesh.SaveAll", 0)
gmsh.option.setNumber("Mesh.SaveGroupsOfElements", 0)
gmsh.option.setNumber("Mesh.SaveGroupsOfNodes", 0)
gmsh.write(OUT_MSH)
gmsh.write(OUT_INP)
# keep only *NODE + *ELEMENT (C3D*)
_clean_inp_to_orphan_mesh(OUT_INP, keep_element_prefixes=("C3D",),
# (optional) export the partitioned CAD
if export_step:
    try:
        gmsh.write(OUT_STP)
        print("[STEP] Exported partitioned STEP:", OUT_STP)
    except Exception:
        print("[STEP] Export failed (writer not available for this geometry).")
print("\n==== Summary ====")
print("STEPs:", len(step_files))
print("h    : {:.6g}".format(target_size))
print("BBox : Lx={:.6g}, Ly={:.6g}, Lz={:.6g}".format(Lx, Ly, Lz))
print("Equal parts/axis:", parts_equal)
print("Copied axes (periodic):", periodic if periodic else "none")
print("3D optimize:", "ON" if keep3dopt else "OFF (strict)")
print("Wrote:\n  - {}\n  - {}".format(OUT_MSH, OUT_INP))
for msg in gmsh.logger.get():
    if ("volumes left to mesh" in msg) or ("Error" in msg) or ("Warning" in msg):
        print("[GMSH]", msg)
gmsh.logger.stop()
gmsh.finalize()
if name == “main”:
main()
