Hi all
I see that it is possible to find the tet ids within a given volume
I was wondering if it is possible to find the volume id given a tet id
Many thanks
Jon
Hi all
Many thanks
Jon
You can use the parse_cubit_list function to get a list of tets in a volume. In the Script tab (enable in Tools-Options-Layout), type
print cubit.parse_cubit_list(“tet”, “in vol 1”)
Or set a variable
tet_ids = cubit.parse_cubit_list(“tet”, “in vol 1”)
print tet_ids
Hi there
Thanks for the reply
I believe this parse_cubit_list command gives me all the tet ids in the volume
I am after a method of finding the volume given an individual tet id
Using the parse_cubit_list method would require searching through the returned list for every volume to see if the tet id that I have is within that list. Something like the code below
def find_volume_id_given_a_tet_id(tet_id_of_interest)
all_volumes_ids = cubit.parse_cubit_list("volume", ' all')
for volume_id in all_volumes_ids:
list_of_tet_ids_in_volume = cubit.parse_cubit_list("tet", "in vol "+str(volume_id))
if tet_id_of_interest in list_of_tet_ids_in_volume:
return volume_id
break
volume_id_of_interest = find_volume_id_given_a_tet_id(10)
I was hoping for a more direct way and faster method, something like this
volume_id_of_interest = get_tet_volumeid(tetid=10)
Do you know if there is a method like this
Many thanks
Jon
Ah, got it. You could use parse_cubit_list with "in tet ". This below will print the volume that includes tet 1:
print cubit.parse_cubit_list(“volume”, “in tet 1”)
Ah perfect, thanks so much this has really sped up my script
