Is it possible to create different orientations of fiber in cubit?
Hi @Nikhil231998,
Cubit does not have built in capability to support orthotropic materials. As a material model no.
I have seen people create geometric sections corresponding to a fiber angle and assign properties to a block defined by each geometric section. Doing that is a significant project.
For changing the fiber orientation, changing orientation of mesh will work?
Here is what I have seen before. The user was creating a test coupon. You can then assign angles to the element sets (blocks) in your analysis code. I don’t know if that captures your use case.
create vertex 0 0 0
create vertex 1 0 0
create vertex 2 3 0
create surface parallelogram vertex 1 2 3
surface 1 copy move x 1 repeat 5
Surface all copy reflect origin 1 3 0 direction 0 1 0
Surface all copy reflect origin 1 6 0 direction 0 1 0
webcut volume all with general plane x move to location at vertex 53
delete volume 25 to 28
webcut volume 18 24 12 6 with general plane x move to location at vertex 70
delete volume 6, 12, 18, 24
block 1 surf 2 to 5 25 40 20 to 23 31 36
block 2 surf 8 to 11 27 38 14 to 17 29 34
mesh surf all
Thankyou for your help.
