Sorry to bother you all, I’m a newbie and have run into some problems during my recent model creation process, I hope you can point out my mistakes or offer some advice.Here is my model parameter file and the specific error.
brick x 200 y 150 z 25
move vol 1 x 100 y 75 z -12.5
brick x 180 y 5 z 5
move volume 2 x 100 y 12.5 z -12.5
brick x 180 y 5 z 5
move vol 3 x 100 y 137.5 z -12.5
brick x 200 y 70 z 5
move vol 4 x 100 y 75 z -12.5
subtract vol 2 from vol 1
subtract vol 3 from vol 5
subtract vol 4 from vol 6
move vol 8 x 100 y 75 z -12.5
jia gan
brick x 80 y 50 z 1
move vol 9 x 100 y 70 z -11.5
brick x 80 y 50 z 1
move vol 10 x 100 y 80 z -13.5
subtract vol 9 from vol 8
subtract vol 10 from vol 11
jia gan
brick x 80 y 50 z 1
move vol 13 x 100 y 70 z -11.5
brick x 80 y 50 z 1
move vol 14 x 100 y 80 z -13.5
split curve 9 distance 10
split curve 10 distance 10
split curve 12 distance 10
split curve 11 distance 10
create surface vertex 113 114 115 116
section volume 7 with surface 85 keep normal
section volume 7 with surface 85 reverse
split curve 93 distance 2
split curve 94 distance 2
split curve 96 distance 2
split curve 95 distance 2
create surface vertex 153 154 155 156
section volume 12 with surface 110 keep normal
section volume 12 with surface 110 reverse
split curve 244 distance 1
split curve 248 distance 1
split curve 253 distance 1
split curve 246 distance 1
create surface vertex 177 178 179 180
section volume 18 with surface 128 keep normal
section volume 18 with surface 128 reverse
split curve 197 distance 5
split curve 199 distance 5
split curve 203 distance 5
split curve 212 distance 5
create surface vertex 201 202 204 203
section volume 16 with surface 144 keep normal
section volume 16 with surface 144 reverse
delete vol 15 17 19 21
vol 7 size 1
mesh vol 7
vol 12 size 1
mesh vol 12
vol 13 size 1
mesh vol 13
vol 14 size 1
mesh vol 14
vol 18 size 1
mesh vol 18
vol 20 size 1
mesh vol 20
vol 22 size 1
mesh vol 22
vol 23 size 1
mesh vol 23
vol 24 size 1
mesh vol 24
and Cubit>mesh vol 18
Volume 18 (Volume 18) may be meshable with scheme submap.
Trying scheme sweep for automation purposes. If
this fails, try manually setting the scheme to submap.
WARNING: Volume 18 must have its meshing scheme explicitly specified;
it is not automatically mappable, submappable or sweepable.
Nothing to match.
ERROR: C:/Users/Q/Desktop/0626-cubit/jia_gan.jou (78). 1 volume did not mesh : Volume 18
