I import an existing facet file and then remesh the surface with a coarser mesh.
Import facets "/Users/radar/SSE/Nicoya_Topo_interface.fac" merge stitch
eading facets...
Building facet-based geometry from 7224 facets...
256 facet vertices on model boundary detected that could not be merged.
Body successfully created.
Number of new vertices = 4
Number of new curves = 4
Number of new surfaces = 1
Number of new shells = 1
Number of new volumes = 1
Number of new bodies = 1
WARNING: Volume generated does not completely close. 3D meshing (ie. hex/tet) will not be permitted.
Hint: In some cases the "stitch" option on the import command may correct the problem.
Geometry engine set to: Facet Geometry Engine version 10.0.0
Journaled Command: import facets "/Users/radar/SSE/Nicoya_Topo_interface.fac" merge stitch
mesh surface 8
Meshing Surface 8 (Surface 8)
Generated 657 tris for Surface 8 (Surface 8).
Surface 8 (Surface 8) meshing completed using scheme: trimesh
It meshes fine within the Trelis interface. However, when I go to export the new mesh to a facet file it exports the same original mesh elements not my new mesh.
export facets "Nicoya_test.fac" surface 8 overwrite
Successfully wrote 7224 facets to file: Nicoya_test.fac
Journaled Command: export facets "Nicoya_test.fac" surface 8 overwrite
What is the best way to go about this?
Nick
