Coreform Cubit Version : 2024.3
Platform : Red Hat Enterprise Linux 8 on HPC Cluster
Issue
Cubit is exporting a corrupt mesh?
I’m trying to export a 670 M element TET4 mesh for use in MOOSE. Cubit is able to generate the mesh with no errors, and there are no errors output during export process. However when I attempt to read the mesh into MOOSE I seg fault, and if I try and read it into Cubit I get
“ERROR: Encountered an uncaught exception ‘vector::_M_default_append’.”
I am exporting using exodus with netcdf4 turned on. I have tried using single precision exodus output as well as trying out the other exodus output options such as “no_ids”. Neither of these have any impact.
I have successfully generated a ~400 M mesh of the same geometry and it doesn’t suffer from the same issue. I’ve ran an interactive HPC session to monitor memory usage while reading the mesh into MOOSE, and I don’t get anywhere near max memory usage on a 512GB node. The only other thing I can think of is that Cubit is running out of memory while exporting, but the log file suggests the mesh was exported successfully.
any help would be much appreciate with this as I’m running out of ideas in terms of what to try:)
Bill
