Export image from Cubit
I would like to export high quality images from Cubit, which I can lateron use in presentations or animations.
Currently I am using the Hardcopy command and export .png, but it is not possible to adjust the image quality, which is in the default settings not sufficient.
Also the .eps file format as output is not performing better.
Is there any possibility to adjust the Hardcopy command with respect to image quality?
Best wishes
Martin
I just found the answer myself in the thread “Image resolution when exporting pictures”. Sorry for that.
Is there any improved functionality in Trelis? At the moment I am using Cubit…
