I stumbled over a small bug while exporting hex20 elements.
When i define the hex20 element for the block before the refinement. i get an error on export.
“Unable to build sequential node IDs (Invalid connectivity) WARNING: Nothing to write.”
hex8 elements doesn’t produce this error. defining the hex20 after refinement also works.
create brick x 10
webcut volume all with plane xplane offset 1
webcut volume all with plane xplane offset -1
webcut volume all with plane yplane offset 1
webcut volume all with plane yplane offset -1
webcut volume all with plane zplane offset 1
webcut volume all with plane zplane offset -1
imprint vol all
set duplicate block elements off
block 1 add volume all
block 1 element type hex20
refine surface 157 247 248 238 189 219 numsplit 1 bias 1.0 depth 1 smooth
export abaqus "test.inp" overwrite
