Our team is trying to run the minimal CommandPlugin in the SDK and it seems like Cubit is failing to successfully load it as it does not appear in the plugins section in the Cubit GUI. We are using 2022.04 installation.
Here are the steps we took:
Copy “\examples\CommandPlugin” to a separate local drive
Run CMake with Cubit_DIR as the cubit installation bin folder.
Generate the project with VS2019 and compile it
Copy the DLL to the plugins folder in bin.
Also tried changing the .dll to .ccg and copying to the bin folder and still no luck.
The plugin was not found at all. It is not listed in the plugin list, and adding extra plugin load directory also does not work.
The strange thing is that after building the Component example and copying the .ccl file into the bin folder, cubit successfully registers this component and it shows in the Plugins menu in Cubit. However, we need the command plugin example to work, since that’s a much more simple example and a better template for what we want to achieve.
Can you please helping us with running this CommandPlugin example?
The CommandPlugin should produce a library file with a .ccm extension. The .ccg extension is for a graphical plugin. Have you tried renaming the .dll to .ccm? Also, are you able to use the latest release of Coreform Cubit? There’s been some fixes to plugin loading in the latest.
I tried changing .dll to .ccm and still it is not showing up in the Plugins window inside Cubit.
I also tried with the latest version, and this time a .ccm file is produced instead of a .dll, but after copying that to the bin folder, it is still not showing up in the Plugins window inside Cubit, leading me to believe that the library is not actually loaded.
When building with CMake, are you building in Debug or Release? On Windows specifically, Cubit will only load plugins built in Release or RelWithDebInfo.
How are you testing if the plugin is loaded or not? I built the plugin on Windows in Release and ran Cubit with the -commandplugindir pointing to the “Release” directory, then ran the new version command. Like this:
C:\Users\wilco\Documents\Cubit_SDK\examples\CommandPlugin\build\Release>dir
Volume in drive C is OS
Volume Serial Number is 568C-6B97
Directory of C:\Users\wilco\Documents\Cubit_SDK\examples\CommandPlugin\build\Release
11/02/2023 01:56 PM <DIR> .
11/02/2023 01:56 PM <DIR> ..
11/02/2023 01:56 PM 43,520 my_plugin.ccm
11/02/2023 01:56 PM 993 my_plugin.exp
11/02/2023 01:56 PM 2,002 my_plugin.lib
3 File(s) 46,515 bytes
2 Dir(s) 103,607,177,216 bytes free
C:\Users\wilco\Documents\Cubit_SDK\examples\CommandPlugin\build\Release>"C:\Program Files\Coreform Cubit 2023.8\bin\coreform_cubit.com" -nog -prompt Cubit -commandplugindir .
Python version 0 selected
Supervisor::Impl::load_plugins: Loaded component: cubitcomp.ccl from directory: C:/Program Files/Coreform Cubit 2023.8/bin
Loading command plugins from .
CCCCC UU UU BBBBBB IIII TTTTTT
CC CC UU UU BB BB II TT
CC UU UU BBBBBB II TT
CCCCC UUUUU BBBBBB IIII TT tm
MESH GENERATION TOOLKIT
FOR
PRE-PROCESSING OF FINITE ELEMENT ANALYSES
User community forum: https://forum.coreform.com
Cubit Version 2023.8 64-Bit Build ac3a4765
VTK Version 9.2.2
ACIS Version 33.0.0.0
Exodus API Version 8.03
MeshGems Version 2.14-1
Copyright 2001-2019 Sandia Corporation
Revised Mon Aug 28 12:52:29 2023 +0000
Running 11/03/2023 06:30:02 AM
CUBIT includes MeshGems by Spatial Inc.
CUBIT includes ACIS software by Spatial Inc.
CUBIT includes LP Solve by Michel Berkelaar.
CUBIT includes VTK by Kitware Inc.
CUBIT includes Exodus II, based on netCDF by UCAR/Unidata.
CUBIT includes VERDICT, by Sandia National Laboratories.
CUBIT includes MESQUITE, by Argonne National Laboratory and
Machine type is Microsoft Windows 10.0 (Build 22621)
Machine name is DESKTOP-OP29DVU
Working Directory: C:\Users\wilco\Documents\Cubit_SDK\examples\CommandPlugin\build\Release\
(Non-Commercial License) CUBIT> version
MyPlugin Version 0.1
Cubit Version 2023.8 Build ac3a4765
VTK Version 9.2.2
Exodus Version 8.03
Finished Command: version
But it seems like this is not the right way of doing it.
After doing the version command in the latest Cubit version, it does indeed show MyPlugin version which should indicate that the plugin is loaded.
But it still does not work in the 2022.04 version.
After building against the 2022.4 version and launching it like this: C:\Program Files\Coreform Cubit 2022.4\bin>coreform_cubit.exe -commandplugindir C:\Users\wilco\Documents\Cubit_SDK\examples\CommandPlugin\build\Release
I’m able to run the version command in the GUI Cubit prompt.
Isn’t the version command supposed to work without even any plugins? I thought the correct behavior is to see MyPlugin Version 0.1 which is what I see when I use the latest version :
