I’m trying to use export dagmc from the svallin plugin on MacOS 11.4 using Cubit 2021.5.  I have a simple model imported from STEP that has only about 5k faces.
I’ve followed the directions here (Producing solid models for DAGMC using Cubit — DAGMC) but on the export command the application closes and produces an error report. The error report is lengthy, but I’ve tried to excerpt it below:
Application Specific Information:
Assertion failed: (0), function serial_create_file, file /Users/runner/work/Cubit-plugin/moab/moab/src/io/WriteHDF5.cpp, line 2497.Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff2053b92e __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff2056a5bd pthread_kill + 263
2 libsystem_c.dylib 0x00007fff204bf411 abort + 120
3 libsystem_c.dylib 0x00007fff204be7e8 __assert_rtn + 314
4 libsvalinn_plugin.so 0x0000000151ba0e3d moab::WriteHDF5::serial_create_file(char const*, bool, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > > > const&, moab::TagInfo* const*, int, int) + 653
5 libsvalinn_plugin.so 0x0000000151b9e6dd moab::WriteHDF5::write_file_impl(char const*, bool, moab::FileOptions const&, unsigned long const*, int, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > > > const&, moab::TagInfo* const*, int, int) + 2493
6 libsvalinn_plugin.so 0x0000000151b9d9a4 moab::WriteHDF5::write_file(char const*, bool, moab::FileOptions const&, unsigned long const*, int, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator > > > const&, moab::TagInfo* const*, int, int) + 564
7 libsvalinn_plugin.so 0x00000001516e96ea moab::Core::write_file(char const*, char const*, char const*, moab::Range const&, moab::TagInfo* const*, int) + 1594
8 libsvalinn_plugin.so 0x00000001516e8fa8 moab::Core::write_file(char const*, char const*, char const*, unsigned long const*, int, moab::TagInfo* const*, int) + 248
9 libsvalinn_plugin.so 0x00000001514360db DAGMCExportCommand::execute(CubitCommandData&) + 3691
I’d appreciate any help or insight you may have.
