Trelis Version : Cubit Coreform 2021.4
Platform : Ubuntu 20.04
Issue
Just wondering if anyone else has seen these error messages when running from the terminal
Error loading component:
libcoreformcae.ccg
libcubitcomp.ccl
libcubitcompgui.ccg
libflexcomp.ccl
libflexgui.ccg
What can we help with?
scot
May 28, 2021, 6:16pm
2
Can you do two things for me please:
export CUBIT_VERBOSE=5
/opt/Coreform-Cubit-2021.4/bin/coreform_cubit
strace -o debug_cubit.txt /opt/Coreform-Cubit-2021.4/bin/coreform_cubit
Please attach the full output of the first command and the generated debug_cubit.txt.
If you installed using the .deb, all dependent libraries should have been installed for you. If you installed the .tar.gz, please make sure the following libraries are installed:
libx11-6
libxt6
libgl1 (If graphics driver is not already installed)
libglu1-mesa (If graphics driver is not already installed)
libgl1-mesa-glx (If graphics driver is not already installed)
libxcb-icccm4
libxcb-image0
libxcb-keysyms1
libxcb-render-util0
libxkbcommon-x11-0
libxcb-randr0
libxcb-xinerama0
libopengl0
Thanks Scot
I installed using the .deb package
Here is the output for the first command
oem@k0281:/opt/Coreform-Cubit-2021.4/bin$ export CUBIT_VERBOSE=5
oem@k0281:/opt/Coreform-Cubit-2021.4/bin$ coreform_cubit
[2021-05-28 19:36:05.800] [app_logger] [info] Using gui
[2021-05-28 19:36:05.938] [info] RLM session initialized
[2021-05-28 19:36:05.938] [app_logger] [debug] RLM Diagnostics at 05/28/2021 19:36
RLM version: 14.1BL3
RLM platform: x64_l1
OS version: 5.8.0-53-generic
ISV name: csimsoft
Hostname: k0281
User: oem
Working directory: /opt/Coreform-Cubit-2021.4/bin
Environment:
RLM_CONNECT_TIMEOUT=<not set>
RLM_LICENSE=<not set>
RLM_NO_UNLIMIT=<not set>
RLM_PATH_RANDOMIZE=<not set>
RLM_PROJECT=<not set>
RLM_QUEUE=<not set>
RLM_ROAM=<not set>
RLMSTAT=<not set>
HTTP_PROXY=<not set>
csimsoft_LICENSE=<not set>
RLM hostid list:
cc60aee9 a4bb6d23fbda ac675d16b926 ip=192.168.0.51
License files:
/opt/Coreform-Cubit-2021.4/bin/licenses/remote.lic
rlm_init() parameters:
1: /opt/Coreform-Cubit-2021.4/bin/licenses
2: /opt/Coreform-Cubit-2021.4/bin/coreform_cubit
3: <empty>
<none>
In license file /opt/Coreform-Cubit-2021.4/bin/licenses/remote.lic
(customer "ukaea" server at: 5053@ls75.rlmcloud.com)
<none>
Roaming Licenses:
<none>
[2021-05-28 19:36:06.987] [app_logger] [debug] Pushing fid: 1, trelis
[2021-05-28 19:36:06.987] [app_logger] [debug] Pushing fid: 4, trelis_core
[2021-05-28 19:36:06.987] [app_logger] [debug] Pushing fid: 2, trelis_fea
[2021-05-28 19:36:06.987] [app_logger] [debug] Pushing fid: 3, trelis_cfd
[2021-05-28 19:36:10.481] [app_logger] [debug] Feature trelis status: 0
[2021-05-28 19:36:12.667] [app_logger] [debug] Feature trelis_core status: 0
[2021-05-28 19:36:13.040] [app_logger] [debug] Feature trelis_fea status: 0
[2021-05-28 19:36:13.380] [app_logger] [debug] Feature trelis_cfd status: 0
[2021-05-28 19:36:13.380] [app_logger] [debug] has_feature: feature_id = 1
[2021-05-28 19:36:13.380] [app_logger] [debug] has_feature: feature_data->valid = 0
[2021-05-28 19:36:13.380] [app_logger] [debug] has_feature: feature_id = 4
[2021-05-28 19:36:13.380] [app_logger] [debug] has_feature: feature_id = 2
[2021-05-28 19:36:13.380] [app_logger] [info] Logged in
[2021-05-28 19:36:13.380] [app_logger] [info] Set OPAL_PREFIX to /opt/Coreform-Cubit-2021.4/bin/mpi
[2021-05-28 19:36:13.380] [app_logger] [info] Set OPAL_LIBDIR to /opt/Coreform-Cubit-2021.4/bin/mpi/lib
[2021-05-28 19:36:13.380] [app_logger] [info] Set OPAL_BINDIR to /opt/Coreform-Cubit-2021.4/bin/mpi/bin
[2021-05-28 19:36:13.381] [app_logger] [info] Python version 0 selected
[2021-05-28 19:36:13.381] [app_logger] [info] Looking for Python
[2021-05-28 19:36:13.381] [app_logger] [info] Python version 2 libname is /opt/Coreform-Cubit-2021.4/bin/././python2/libcubit_python2.so
[2021-05-28 19:36:13.385] [app_logger] [info] Python not already initialized, initializing
[2021-05-28 19:36:13.385] [app_logger] [info] Setting program name to coreform_cubit
[2021-05-28 19:36:13.385] [app_logger] [info] Application directory is /opt/Coreform-Cubit-2021.4/bin/./.
[2021-05-28 19:36:13.386] [app_logger] [info] python_lib path: /opt/Coreform-Cubit-2021.4/bin/././python2/./libpython2.7.so.1.0
[2021-05-28 19:36:13.386] [app_logger] [info] python_dir: /opt/Coreform-Cubit-2021.4/bin/././python2/.
[2021-05-28 19:36:13.386] [app_logger] [info] Found embedded python
[2021-05-28 19:36:13.386] [app_logger] [info] PYTHONHOME set to /opt/Coreform-Cubit-2021.4/bin/././python2
[2021-05-28 19:36:13.453] [app_logger] [info] Version 2 interpreter found
[2021-05-28 19:36:13.454] [app_logger] [info] Cubit python initialized
[2021-05-28 19:36:13.454] [app_logger] [info] Starting broker
[2021-05-28 19:36:13.454] [app_logger] [info] Passing control to MachineControl
[2021-05-28 19:36:13.461] [app_logger] [debug] Dealer::restore_settings: loading QSettings from : /home/oem/.config/Coreform/Cubit.ini
[2021-05-28 19:36:13.461] [app_logger] [debug] Supervisor::Impl::load_plugins: Loading plugins from QCoreApplication::applicationDirPath : /opt/Coreform-Cubit-2021.4/bin
[2021-05-28 19:36:13.461] [app_logger] [info] Loading plugin from path /opt/Coreform-Cubit-2021.4/bin
[2021-05-28 19:36:13.462] [app_logger] [info] Attempting to load: libcoreformcae.ccg
[2021-05-28 19:36:13.462] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.4/bin/libcoreformcae.ccg
[2021-05-28 19:36:13.468] [app_logger] [error] dlopen error: /opt/Coreform-Cubit-2021.4/bin/libcoreformcae.ccg libOpenGL.so.0: cannot open shared object file: No such file or directory
[2021-05-28 19:36:13.468] [app_logger] [error] Error loading component libcoreformcae.ccg:
libcoreformcae.ccg
[2021-05-28 19:36:13.469] [app_logger] [info] Attempting to load: libcubitcomp.ccl
[2021-05-28 19:36:13.469] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.4/bin/libcubitcomp.ccl
[2021-05-28 19:36:13.472] [app_logger] [error] dlopen error: /opt/Coreform-Cubit-2021.4/bin/libcubitcomp.ccl libOpenGL.so.0: cannot open shared object file: No such file or directory
[2021-05-28 19:36:13.472] [app_logger] [error] Error loading component libcubitcomp.ccl:
libcubitcomp.ccl
[2021-05-28 19:36:13.472] [app_logger] [info] Attempting to load: libcubitcompgui.ccg
[2021-05-28 19:36:13.472] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.4/bin/libcubitcompgui.ccg
[2021-05-28 19:36:13.474] [app_logger] [error] dlopen error: /opt/Coreform-Cubit-2021.4/bin/libcubitcompgui.ccg libOpenGL.so.0: cannot open shared object file: No such file or directory
[2021-05-28 19:36:13.474] [app_logger] [error] Error loading component libcubitcompgui.ccg:
libcubitcompgui.ccg
[2021-05-28 19:36:13.474] [app_logger] [info] Attempting to load: libflexcomp.ccl
[2021-05-28 19:36:13.474] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.4/bin/libflexcomp.ccl
[2021-05-28 19:36:13.493] [app_logger] [error] dlopen error: /opt/Coreform-Cubit-2021.4/bin/libflexcomp.ccl libOpenGL.so.0: cannot open shared object file: No such file or directory
[2021-05-28 19:36:13.493] [app_logger] [error] Error loading component libflexcomp.ccl:
libflexcomp.ccl
[2021-05-28 19:36:13.493] [app_logger] [info] Attempting to load: libflexgui.ccg
[2021-05-28 19:36:13.493] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.4/bin/libflexgui.ccg
[2021-05-28 19:36:13.514] [app_logger] [error] dlopen error: /opt/Coreform-Cubit-2021.4/bin/libflexgui.ccg libOpenGL.so.0: cannot open shared object file: No such file or directory
[2021-05-28 19:36:13.515] [app_logger] [error] Error loading component libflexgui.ccg:
libflexgui.ccg
scot
May 28, 2021, 6:40pm
4
This is the actual error. This can be fixed by installing the libopengl0 package from apt.
Thanks Scot that has worked.
Is that package normally included in the .deb file
scot
May 28, 2021, 6:44pm
6
It wasn’t always included in the .deb installer, but it is now in the latest downloads. Glad to hear that fixed your problem!
Just for fun I removed the libopengl0 with apt-get remove libopengl0 and installed 2021.5 using the deb and it worked straight away.
Nice progress you are making, every version appears better and better, congrats
scot
May 28, 2021, 7:00pm
8
Thanks! That means a lot, we’ve been working hard.
