Hi rkendrick, it’s likely that you’ve got something in your system configured that’s making Coreform Cubit 2022.4 load libraries from Trelis 17.1. What’s the value of your $LD_LIBRARY_PATH and $PATH environment variables?
If you don’t see anything pointing to Trelis 17.1, please take a system call log like this:
I removed all specific paths to Trelis locations from $LD_LIBRARY_PATH and $PATH, still getting the error. Could potentially be an overlap in /usr/local but I think the strace would highlight that hopefully.
The strace isn’t showing anything that really stands out as wrong, actually. Please set the environment variable CUBIT_VERBOSE=5 and try running coreform_cubit again, then please send me the full output.
