Correct, I am just getting the framework. Cubit functionality is missing from GUI.
downloading Coreform-Cubit-2021.3.0-Lin64.tar.gz
double click and extract to my HOME directory
sudo apt-get update -y
sudo apt-get install -y libx11-6
sudo apt-get install -y libxt6 libgl1 libglu1-mesa libgl1-mesa-glx libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-render-util0 libxkbcommon-x11-0 libxcb-randr0 libxcb-xinerama0
~/Coreform-Cubit-2021.3-Lin64$ ./bin/coreform_cubit
GUI appeared, but without cubit functionality.
strace -o debug_cubit.txt ./coreform_cubit
more debug_cubit.txt
execve(“./coreform_cubit”, [“./coreform_cubit”], 0x7ffe93630b10 /* 50 vars /) = 0
brk(NULL) = 0x1b48000
arch_prctl(0x3001 / ARCH_??? */, 0x7ffeb0844650) = -1 EINVAL (Invalid argument)
readlink(“/proc/self/exe”, “/home/kim/Coreform-Cubit-2021.3-”…, 4096) = 56
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f4d1967f000
access(“/etc/ld.so.preload”, R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls/haswell/x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat(“/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls/haswell/x86_64”, 0x7ffeb08438a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls/haswell/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat(“/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls/haswell”, 0x7ffeb08438a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls/x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat(“/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls/x86_64”, 0x7ffeb08438a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat(“/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./tls”, 0x7ffeb08438a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./haswell/x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat(“/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./haswell/x86_64”, 0x7ffeb08438a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./haswell/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat(“/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./haswell”, 0x7ffeb08438a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat(“/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./x86_64”, 0x7ffeb08438a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./libclarogui.so”, O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\264\2\0\0\0\0\0”…, 832) = 832
pread64(3, “\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0”…, 784, 64) = 784
pread64(3, “\4\0\0\0\24\0\0\0\3\0\0\0GNU\0.\313\20\345\276_\211\334z\244u\357\321w\343Y”…, 36, 746432) = 36
fstat(3, {st_mode=S_IFREG|0755, st_size=970912, …}) = 0
mmap(NULL, 970912, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f4d19591000
mmap(0x7f4d195b9000, 339968, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x7f4d195b9000
mmap(0x7f4d1960c000, 155648, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7b000) = 0x7f4d1960c000
mmap(0x7f4d19632000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa0000) = 0x7f4d19632000
mmap(0x7f4d19639000, 61440, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa8000) = 0x7f4d19639000
mmap(0x7f4d19648000, 53248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb7000) = 0x7f4d19648000
mmap(0x7f4d19655000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc4000) = 0x7f4d19655000
mmap(0x7f4d19663000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd2000) = 0x7f4d19663000
mmap(0x7f4d19671000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe0000) = 0x7f4d19671000
close(3) = 0
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/./libpthread.so.0”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/home/kim/Coreform-Cubit-2021.3-Lin64/bin/../lib/tls/haswell/x86_64/libpthread.so.0”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
