Error loading component-Cubit Learn 2021.11
I just started using Cubit, and I am having the following error messages.
I believe these errors are causing limited Cubit functionalities, as can be seen on the screenshot. Please could someone help?
Please set the following environment variable, start Cubit again, and post the full output:
export CUBIT_VERBOSE=5
coreform_cubit
HI,
Thanks for your reply. Please find attached the full output:
[2022-01-21 12:34:32.141] [app_logger] [info] Using gui
[2022-01-21 12:34:32.362] [info] RLM session initialized
[2022-01-21 12:34:32.366] [app_logger] [debug] RLM Diagnostics at 01/21/2022 12:34
RLM version: 14.1BL3
RLM platform: x64_l1
OS version: 4.4.0-19041-Microsof
ISV name: csimsoft
Hostname: lapepcmg01
User: ceormond
Working directory: /home/ceormond
Environment:
    RLM_CONNECT_TIMEOUT=<not set>
    RLM_LICENSE=<not set>
    RLM_NO_UNLIMIT=<not set>
    RLM_PATH_RANDOMIZE=<not set>
    RLM_PROJECT=<not set>
    RLM_QUEUE=<not set>
    RLM_ROAM=<not set>
    RLMSTAT=<not set>
    HTTP_PROXY=<not set>
    csimsoft_LICENSE=<not set>
RLM hostid list:
    7f0101 aa64f1bebd65 a864f1bebd66 00ffa8e04558 a864f1bebd65 a864f1bebd69 ip=169.254.227.178 ip=10.11.74.26 ip=192.168.1.178 ip=169.254.231.64 ip=169.254.108.104
License files:
rlm_init() parameters:
1: /opt/Coreform-Cubit-2021.11/bin/licenses:/home/ceormond/.config/Coreform/licenses
2: /opt/Coreform-Cubit-2021.11/bin/coreform_cubit
3:
    <none>
Roaming Licenses:
    <none>
L
[2022-01-21 12:34:34.367] [app_logger] [error] No logins were valid: -1
[2022-01-21 12:34:35.216] [app_logger] [info] Valid Cubit Learn login
[2022-01-21 12:34:35.216] [app_logger] [info] Logged in
[2022-01-21 12:34:35.216] [app_logger] [info] Set OPAL_PREFIX to /opt/Coreform-Cubit-2021.11/bin/mpi
[2022-01-21 12:34:35.216] [app_logger] [info] Set OPAL_LIBDIR to /opt/Coreform-Cubit-2021.11/bin/mpi/lib
[2022-01-21 12:34:35.216] [app_logger] [info] Set OPAL_BINDIR to /opt/Coreform-Cubit-2021.11/bin/mpi/bin
[2022-01-21 12:34:35.217] [app_logger] [info] Python version 0 selected
[2022-01-21 12:34:35.217] [app_logger] [info] Looking for Python
[2022-01-21 12:34:35.217] [app_logger] [info] Python version 3 libname is /opt/Coreform-Cubit-2021.11/bin/././python3/libcubit_python3.so
[2022-01-21 12:34:35.223] [app_logger] [info] Python not already initialized, initializing
[2022-01-21 12:34:35.223] [app_logger] [info] Setting program name to coreform_cubit
[2022-01-21 12:34:35.223] [app_logger] [info] Application directory is /opt/Coreform-Cubit-2021.11/bin/./.
[2022-01-21 12:34:35.223] [app_logger] [info] python_lib path: /opt/Coreform-Cubit-2021.11/bin/././python3/./libpython3.8.so.1.0
[2022-01-21 12:34:35.223] [app_logger] [info] python_dir: /opt/Coreform-Cubit-2021.11/bin/././python3/.
[2022-01-21 12:34:35.223] [app_logger] [info] Found embedded python
[2022-01-21 12:34:35.223] [app_logger] [info] PYTHONHOME set to /opt/Coreform-Cubit-2021.11/bin/././python3
[2022-01-21 12:34:35.236] [app_logger] [info] Version 3 interpreter found
[2022-01-21 12:34:35.237] [app_logger] [info] Cubit python initialized
[2022-01-21 12:34:35.237] [app_logger] [info] Starting broker
[2022-01-21 12:34:35.237] [app_logger] [info] Passing control to MachineControl
[2022-01-21 12:34:35.247] [app_logger] [debug] Dealer::restore_settings: loading QSettings from : /home/ceormond/.config/Coreform/Cubit.ini
[2022-01-21 12:34:35.247] [app_logger] [debug] Supervisor::Impl::load_plugins: Loading plugins from QCoreApplication::applicationDirPath : /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:34:35.247] [app_logger] [info] Loading plugin from path /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:34:35.248] [app_logger] [info] Attempting to load: libcfplugincomp.ccl
[2022-01-21 12:34:35.249] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcfplugincomp.ccl
[2022-01-21 12:34:36.075] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugincomp.ccl from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:34:36.075] [app_logger] [debug] Registering plugin components
[2022-01-21 12:34:36.075] [app_logger] [info] Attempting to load: libcfplugingui.ccg
[2022-01-21 12:34:36.075] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcfplugingui.ccg
[2022-01-21 12:34:36.108] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugingui.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:34:36.109] [app_logger] [debug] Registering plugin components
[2022-01-21 12:34:36.109] [app_logger] [info] Attempting to load: libcoreformcae.ccg
[2022-01-21 12:34:36.109] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcoreformcae.ccg
[2022-01-21 12:34:36.186] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcoreformcae.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:34:36.186] [app_logger] [debug] Registering plugin components
[2022-01-21 12:34:36.186] [app_logger] [info] Attempting to load: libcubitcomp.ccl
[2022-01-21 12:34:36.186] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcubitcomp.ccl
[2022-01-21 12:34:36.191] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcomp.ccl from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:34:36.191] [app_logger] [debug] Registering plugin components
[2022-01-21 12:34:36.191] [app_logger] [info] Attempting to load: libcubitcompgui.ccg
[2022-01-21 12:34:36.191] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcubitcompgui.ccg
[2022-01-21 12:34:36.205] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcompgui.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:34:36.205] [app_logger] [debug] Registering plugin components
Creating new Workspace session
Initializing LLVM
[2022-01-21 12:34:36.594] [error] dlopen ERROR /opt/Coreform-Cubit-2021.11/bin/././plugins/libsvalinn_plugin.so : libMOAB.so.5: cannot open shared object file: No such file or directory
[2022-01-21 12:34:36.594] [error] Error loading /opt/Coreform-Cubit-2021.11/bin/././plugins/libsvalinn_plugin.so:
FAILED LOADING PLUGIN /opt/Coreform-Cubit-2021.11/bin/././plugins/libsvalinn_plugin.so
Loading workspace command plugin
I’m not aware of what libsvalinn_plugin.so or libMOAB.so.5 are, we don’t ship those with Cubit and they’re not required for Cubit usage. It sounds like you’ve either got something in LD_LIBRARY_PATH that’s loading those libraries, or a custom Qt setup. Cubit comes with its own version of Qt, so if you have a Qt installation in LD_LIBRARY_PATH or pointed to by global Qt environment variables please remove it from those variables. Please try running Coreform Cubit like this:
LD_LIBRARY_PATH="" coreform_cubit
I just ran cubit as per your instructions, the GUI looks better, with more functionalities, although there is a lot of overlap. I attached a screenshot of the GUI:
Please find below the full output. It still returns an error at the end. Is it simply caused by this additional plugin? (needed for another software) Should I try removing it?
[2022-01-21 12:49:37.609] [app_logger] [info] Using gui
[2022-01-21 12:49:37.823] [info] RLM session initialized
[2022-01-21 12:49:37.829] [app_logger] [debug] RLM Diagnostics at 01/21/2022 12:49
ISV name: csimsoft
User: ceormond
Environment:
    RLM_QUEUE=<not set>
    RLM_ROAM=<not set>
    RLMSTAT=<not set>
RLM hostid list:
License files:
3:
    <none>
Roaming Licenses:
    <none>
[2022-01-21 12:49:39.830] [app_logger] [error] No logins were valid: -1
[2022-01-21 12:49:40.666] [app_logger] [info] Valid Cubit Learn login
[2022-01-21 12:49:40.666] [app_logger] [info] Logged in
[2022-01-21 12:49:40.666] [app_logger] [info] Set OPAL_PREFIX to /opt/Coreform-Cubit-2021.11/bin/mpi
[2022-01-21 12:49:40.666] [app_logger] [info] Set OPAL_LIBDIR to /opt/Coreform-Cubit-2021.11/bin/mpi/lib
[2022-01-21 12:49:40.666] [app_logger] [info] Set OPAL_BINDIR to /opt/Coreform-Cubit-2021.11/bin/mpi/bin
[2022-01-21 12:49:40.666] [app_logger] [info] Python version 0 selected
[2022-01-21 12:49:40.666] [app_logger] [info] Looking for Python
[2022-01-21 12:49:40.666] [app_logger] [info] Python version 3 libname is /opt/Coreform-Cubit-2021.11/bin/././python3/libcubit_python3.so
[2022-01-21 12:49:40.672] [app_logger] [info] Python not already initialized, initializing
[2022-01-21 12:49:40.672] [app_logger] [info] Setting program name to coreform_cubit
[2022-01-21 12:49:40.672] [app_logger] [info] Application directory is /opt/Coreform-Cubit-2021.11/bin/./.
[2022-01-21 12:49:40.672] [app_logger] [info] python_lib path: /opt/Coreform-Cubit-2021.11/bin/././python3/./libpython3.8.so.1.0
[2022-01-21 12:49:40.672] [app_logger] [info] python_dir: /opt/Coreform-Cubit-2021.11/bin/././python3/.
[2022-01-21 12:49:40.672] [app_logger] [info] Found embedded python
[2022-01-21 12:49:40.672] [app_logger] [info] PYTHONHOME set to /opt/Coreform-Cubit-2021.11/bin/././python3
[2022-01-21 12:49:40.685] [app_logger] [info] Version 3 interpreter found
[2022-01-21 12:49:40.686] [app_logger] [info] Cubit python initialized
[2022-01-21 12:49:40.686] [app_logger] [info] Starting broker
[2022-01-21 12:49:40.686] [app_logger] [info] Passing control to MachineControl
[2022-01-21 12:49:40.696] [app_logger] [debug] Dealer::restore_settings: loading QSettings from : /home/ceormond/.config/Coreform/Cubit.ini
[2022-01-21 12:49:40.696] [app_logger] [debug] Supervisor::Impl::load_plugins: Loading plugins from QCoreApplication::applicationDirPath : /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:49:40.696] [app_logger] [info] Loading plugin from path /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:49:40.698] [app_logger] [info] Attempting to load: libcfplugincomp.ccl
[2022-01-21 12:49:40.698] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcfplugincomp.ccl
[2022-01-21 12:49:41.328] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugincomp.ccl from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:49:41.328] [app_logger] [debug] Registering plugin components
[2022-01-21 12:49:41.328] [app_logger] [info] Attempting to load: libcfplugingui.ccg
[2022-01-21 12:49:41.328] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcfplugingui.ccg
[2022-01-21 12:49:41.360] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugingui.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:49:41.360] [app_logger] [debug] Registering plugin components
[2022-01-21 12:49:41.360] [app_logger] [info] Attempting to load: libcoreformcae.ccg
[2022-01-21 12:49:41.360] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcoreformcae.ccg
[2022-01-21 12:49:41.437] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcoreformcae.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:49:41.437] [app_logger] [debug] Registering plugin components
[2022-01-21 12:49:41.437] [app_logger] [info] Attempting to load: libcubitcomp.ccl
[2022-01-21 12:49:41.437] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcubitcomp.ccl
[2022-01-21 12:49:41.442] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcomp.ccl from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:49:41.442] [app_logger] [debug] Registering plugin components
[2022-01-21 12:49:41.443] [app_logger] [info] Attempting to load: libcubitcompgui.ccg
[2022-01-21 12:49:41.443] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcubitcompgui.ccg
[2022-01-21 12:49:41.457] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcompgui.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 12:49:41.457] [app_logger] [debug] Registering plugin components
Initializing LLVM
[2022-01-21 12:49:41.819] [error] dlopen ERROR /opt/Coreform-Cubit-2021.11/bin/././plugins/libsvalinn_plugin.so : libMOAB.so.5: cannot open shared object file: No such file or directory
[2022-01-21 12:49:41.819] [error] Error loading /opt/Coreform-Cubit-2021.11/bin/././plugins/libsvalinn_plugin.so:
^CSIGINT OCCURRED
libsvalinn_plugin.so is not shipped with Cubit, so I’m not sure why it’s showing up in your Cubit installation. Go ahead and remove it.
Hi Scot,
I deleted the plugin. Here is the full output:
coreform_cubit
[2022-01-21 15:04:58.629] [app_logger] [info] Using gui
[2022-01-21 15:04:59.732] [info] RLM session initialized
[2022-01-21 15:04:59.738] [app_logger] [debug] RLM Diagnostics at 01/21/2022 15:04
ISV name: csimsoft
User: ceormond
Environment:
    RLM_QUEUE=<not set>
    RLM_ROAM=<not set>
    RLMSTAT=<not set>
RLM hostid list:
License files:
3:
    <none>
Roaming Licenses:
    <none>
4
[2022-01-21 15:05:01.739] [app_logger] [error] No logins were valid: -1
[2022-01-21 15:05:02.622] [app_logger] [info] Valid Cubit Learn login
[2022-01-21 15:05:02.622] [app_logger] [info] Logged in
[2022-01-21 15:05:02.622] [app_logger] [info] Set OPAL_PREFIX to /opt/Coreform-Cubit-2021.11/bin/mpi
[2022-01-21 15:05:02.622] [app_logger] [info] Set OPAL_LIBDIR to /opt/Coreform-Cubit-2021.11/bin/mpi/lib
[2022-01-21 15:05:02.622] [app_logger] [info] Set OPAL_BINDIR to /opt/Coreform-Cubit-2021.11/bin/mpi/bin
[2022-01-21 15:05:02.622] [app_logger] [info] Python version 0 selected
[2022-01-21 15:05:02.623] [app_logger] [info] Looking for Python
[2022-01-21 15:05:02.623] [app_logger] [info] Python version 3 libname is /opt/Coreform-Cubit-2021.11/bin/././python3/libcubit_python3.so
[2022-01-21 15:05:02.651] [app_logger] [info] Python not already initialized, initializing
[2022-01-21 15:05:02.651] [app_logger] [info] Setting program name to coreform_cubit
[2022-01-21 15:05:02.651] [app_logger] [info] Application directory is /opt/Coreform-Cubit-2021.11/bin/./.
[2022-01-21 15:05:02.652] [app_logger] [info] python_lib path: /opt/Coreform-Cubit-2021.11/bin/././python3/./libpython3.8.so.1.0
[2022-01-21 15:05:02.652] [app_logger] [info] python_dir: /opt/Coreform-Cubit-2021.11/bin/././python3/.
[2022-01-21 15:05:02.652] [app_logger] [info] Found embedded python
[2022-01-21 15:05:02.652] [app_logger] [info] PYTHONHOME set to /opt/Coreform-Cubit-2021.11/bin/././python3
[2022-01-21 15:05:02.745] [app_logger] [info] Version 3 interpreter found
[2022-01-21 15:05:02.746] [app_logger] [info] Cubit python initialized
[2022-01-21 15:05:02.746] [app_logger] [info] Starting broker
[2022-01-21 15:05:02.746] [app_logger] [info] Passing control to MachineControl
[2022-01-21 15:05:02.798] [app_logger] [debug] Dealer::restore_settings: loading QSettings from : /home/ceormond/.config/Coreform/Cubit.ini
[2022-01-21 15:05:02.798] [app_logger] [debug] Supervisor::Impl::load_plugins: Loading plugins from QCoreApplication::applicationDirPath : /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 15:05:02.798] [app_logger] [info] Loading plugin from path /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 15:05:02.800] [app_logger] [info] Attempting to load: libcfplugincomp.ccl
[2022-01-21 15:05:02.800] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcfplugincomp.ccl
[2022-01-21 15:05:04.823] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugincomp.ccl from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 15:05:04.823] [app_logger] [debug] Registering plugin components
[2022-01-21 15:05:04.823] [app_logger] [info] Attempting to load: libcfplugingui.ccg
[2022-01-21 15:05:04.823] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcfplugingui.ccg
[2022-01-21 15:05:04.883] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugingui.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 15:05:04.883] [app_logger] [debug] Registering plugin components
[2022-01-21 15:05:04.883] [app_logger] [info] Attempting to load: libcoreformcae.ccg
[2022-01-21 15:05:04.883] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcoreformcae.ccg
[2022-01-21 15:05:05.100] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcoreformcae.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 15:05:05.100] [app_logger] [debug] Registering plugin components
[2022-01-21 15:05:05.100] [app_logger] [info] Attempting to load: libcubitcomp.ccl
[2022-01-21 15:05:05.100] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcubitcomp.ccl
[2022-01-21 15:05:05.109] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcomp.ccl from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 15:05:05.109] [app_logger] [debug] Registering plugin components
[2022-01-21 15:05:05.109] [app_logger] [info] Attempting to load: libcubitcompgui.ccg
[2022-01-21 15:05:05.109] [app_logger] [debug] ClaroPlugin::load: loading: /opt/Coreform-Cubit-2021.11/bin/libcubitcompgui.ccg
[2022-01-21 15:05:05.149] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcompgui.ccg from directory: /opt/Coreform-Cubit-2021.11/bin
[2022-01-21 15:05:05.149] [app_logger] [debug] Registering plugin components
Initializing LLVM
^CSIGINT OCCURRED
I noticed and error message on the top :
Should I be concerned by this?
Thanks for your great help
No, that’s fine. That’s our license manager checking for paid licenses, you’ll see right under that it says “Valid Cubit Learn login”.
