Hello
After refinement an irregular volume the element size is reduced but is it possible to know at least the maximum (or range of values of) element size obtained in the whole volume.
Hello
You might try using a quality command on those elements. Choose the ‘relative size’ metric, then display by ranking the quality into the top N and bottom N elements. That might give you an idea of the range of sizes.
