Hello!
I’d like to create a surface triangular mesh of a non-manifold geometry and pass to the exodus file the information that describes for each triangle that lies on an interface of volumes, to which volume of the interface does it point to. What is the best strategy to do this task?
What I’ve tried to do so far is: after creating the geometry and merging all the surfaces, then I scan each pair of volumes and create the corresponding groups (Let’s say that we have 5 volumes. The command: group 5 add surface in volume 1 except surface in volume 2 3 4 with is_merged. This command will add to group 5 the surfaces that lie on the boundary of volumes 1 and 5). Consequently, I define the orientation of the group (for example: surface in group 5 normal volume 1) and eventually I create a block for each group. Therefore I can finally write to the exodus file as an attribute the two volumes that each mesh triangle lies on the interface of as well as its orientation.
However, the resulting number of blocks is huge (obviously).
Is there a more formal way/strategy to complete this task?
Thanks in advance for any kind of help!
Keep up the good work!
