Curve Fillet_Error
I have two lines, let’s say with id 1 & 2. They are are connected at a point. I wish to fillet the two lines at their connection (please check image below, i wish to fillet at the RED vertex). I am using the following command:
Tweak Curve 1 2 Fillet Radius 1
It’s giving an error “Attempted get of empty DLIList”. Any suggestions are welcome. Thanks!
Regards,
Aakash
Cubit does not currently support fillets on free curves. We have a sketching tool on the schedule that will resolve this issue.
With the current version you must create a surface and fillet at the vertex. Here is an example of a workaround.
create curve location 0 0 0 location 1 0 0
create curve location 0 0 0 location 0 1 0
create curve vertex 2 4
create surface curve 1 2 3
tweak vertex 1 fillet radius .25
delete surf 1 keep
del curve 3
That’s a smart way to workaround. I have one more query, after the above operation, there are now 3 curves in total. Is it possible to unite them into a single continuous curve ?
Thank you !
You can combine curves if they have first derivative continuity. In this case they will meet that criteria.
In the GUI the option is under Geometry/Curve/Create/Combine
create curve combine curve 1 2 4 delete
The delete option deletes the internal vertices as well as the original curves.
That addresses my queries neatly. Thanks again :slight_smile:
Regards,
Aakash
