Yes, I am trying to build a full hex mesh. I tried meshing the group of surfaces, which seems to work:
Smoothing Surface Mesh
WARNING: >>>>Poor Quality Shape Face Generated!<<<< on Surface 2777
(For example, the Shape metric for Face 376546 is 0.192933 .)
The threshold for a Face is 0.2
WARNING: >>>>Poor Quality Shape Face Generated!<<<< on Surface 2785
(For example, the Shape metric for Face 377047 is 0.122622 .)
WARNING: >>>>Poor Quality Shape Face Generated!<<<< on Surface 2848
(For example, the Shape metric for Face 377588 is 0.0856395 .)
Surfaces 1350, 1351, 1360, 1361, 1370, 1371, 1380, 1381, 1390, 1391, 1400, 1401,
1410, 1411, 1420, 1421, 1431, 1440, 1441, 1451, 1460, 1461, 1471, 1480, 1481,
1490, 1491, 1517, 2466, 2618, 2630, 2743, 2750, 2777, 2785, 2848, 2853, 2858 meshing completed using scheme: pave
Surfaces 426 meshing completed using scheme: map
Generated 5968 quads
Meshing time: 1.005806
Finished Command: mesh surface 426 1350 1351 1360 1361 1370 1371 1380 1381 1390 1391 1400 1401 1410 1411 1420 1421 1431 1440 1441 1451 1460 1461 1471 1480 1481 1490 1491 1517 2466 2618 2630 2743 2750 2777 2785 2848 2853 2858
Finished Command: undo group end
After the mesh is completed, cubit hangs for at least a few seconds after the Finished Command: mesh surface .... It is not as bad as in the 3D case, where the hang-ups were over a minute. When I try to mesh the volume afterwards, it aborts immediately. I guess at least this way I can avoid the waiting time when directly meshing the volume and keep working on the decomposition.
