Dear experts,
I have tried to install Coreform Cubit
I have these files:
I don’t know how to proceed.
Best regards,
Lovepreet
Dear experts,
Best regards,
Lovepreet
You should get the latest downloads from https://coreform.com/products/downloads/. There’s a .deb installer there that should install everything automatically for you.
Thanks for your reply, Sir. I managed to install it. However, I don’t know how to start it. Is there any manual or any tutorial to use it from ubuntu?
Best regards,
Lovepreet
The user manual is here: https://coreform.com/cubit_help/cubithelp.htm#t=mesh_generation%2Ftrelis_users_manual.html
The tutorials are here: https://coreform.com/products/coreform-cubit/tutorials/
Answers to the “Frequently Asked Questions” are here: https://coreform.com/products/coreform-cubit/cubit-faqs/
The error you’re showing can occur when you either don’t have a graphical environment (you only have a terminal) or your graphics aren’t configured correctly.  If you don’t have a graphical environment, you can use Coreform Cubit from the terminal only by passing the flags -nographics -prompt Cubit, like this:
coreform_cubit -nographics -prompt Cubit
If you do have a graphical environment, then you can take a system call log like this;
strace -o debug_cubit.txt coreform_cubit
Please attach the generated debug_cubit.txt to this post and we’ll help you figure out the issue.  If you don’t have strace, you can install it with
sudo apt-get install strace
Thanks for your reply Sir,
I have already tried with coreform_cubit -nographics -prompt Cubit and it asks me the licence
strace -o debug_cubit.txt coreform_cubitBest regards,
Lovepreet
The graphics error is this:
socket(AF_UNIX, SOCK_STREAM|SOCK_CLOEXEC, 0) = 4
connect(4, {sa_family=AF_UNIX, sun_path=@"/tmp/.X11-unix/X0"}, 20) = -1
ECONNREFUSED (Connection refused)
close(4)                                = 0
getsockopt(4, SOL_SOCKET, SO_SNDBUF, [0], [4]) = 0
setsockopt(4, SOL_SOCKET, SO_SNDBUF, [65536], 4) = 0
connect(4, {sa_family=AF_UNIX, sun_path="/tmp/.X11-unix/X0"}, 110) = -1 ENOENT
(No such file or directory)
close(4)
That means that Cubit is attempting to connect to a X11 socket (that’s your graphics display) and the connection is being refused. Are you connecting to this machine via SSH? You may need to configure X forwarding, or there could be a permissions issue.
For a Cubit Learn license you will need the graphics to work in order to activate.
Thank you for your reply, Sir.
I managed to run Cubit GUI application through Xephyr.
