Create curve arc three
version 2020.2
windows 64
I am having what seems to be a tolerance issue with “create curve arc three”. all three curves are coplanar, but I get an ACIS error when I enter
create curve arc three curve 1 2 3 full
Is there a tolerance setting that lets this command work?
cubit02.cub (12.0 KB)
What are you expecting for a result?
The documentation for this command states:
6 . Arc Three: The following command creates an arc either through 3 vertices or tangent to 3 curves. The Full qualifier will cause a complete circle to be created.
The ACIS geometry engine cannot find the arc tangent point on the circles so it fails.
This is a more common use case.
It should (and sometimes does) give this result
If it fails, I discovered a workaround. By extending the line, Cubit draws the circle on the other side:
Then I have to make a series of geometric transformations to mirror the circle to the correct position.
This tells me that maybe there is a parity problem with the algorithm. It only finds a solution for certain orientations of the line.
Thank you your report. We will have to examine the algorithm.
I upgraded to 2021.4, but am experiencing the same issues. I am attaching a script that shows highly variable behavior of this function for different straight lines and on translations.curves.cub (19.6 KB) arc3.jou (952 Bytes)
