Converting mesh-based geometry to real geometry is challenging. When I ran your script, I didn’t get the same error you did. The error that I get when running this script is
ERROR: Surface 1 must have scheme map or submap mesh for net surface approximation
You might try a little trick to get a surface that will work with the “create acis surf 1” command to make ACIS geometry. Try this
import facets “Top_6A_se_2_200m.facet” feature_angle 135.00 merge make_elements stitch #you get tets importing this way, so you could import without “make_elements”
del mesh
composite create surf all #creates one surface
mesh surf 3
export stl “vol1.stl” surf 3 mesh overwrite #this exports the mesh only
import stl “vol1.stl” #import the mesh to create a single surface
mesh surf 1
create acis surf 1
del vol 1
But there is a problem with creating acis surf using “mesh surf 1” and “create acis surf 1.” The mesh lines become part of the acis surface. I don’t want that because when I use this surface to do boolean operations inside a volume, these mesh lines will be imprinted on the volume. I don’t want to use these mesh lines in the final tetmesh that will be created inside this volume.
