Coreform IGA Update: model tree, probe output, linear statics (date change)
On April 22, 2022 (9am MST) Coreform’s Clint Nicely, will host a webinar. He will show how Coreform IGA can be used to run a single component linear statics simulation on a complex part prepared in Coreform Cubit without any defeaturing in under 15 minutes. He will then compare this Coreform IGA approach with the traditional defeatured meshing approach in Coreform Cubit to show the value of this new workflow.
Register here: Webinar Registration - Zoom
Is it possible to also upload the 9 min model tree demonstration video from the webinar? Because the resolution and the fast forward makes it hard to follow the workflow steps.
Hi @Norbert_Hofbauer
I was able to get access to the sped-up version but not the full nine-minute version. Will this help at least step though it slowly? You can download the file from the link below.
http://transfer.coreform.com/HYkTD/Nist-Model-10-Minutes-1.m4v
Hello Karl,
yes that helps a lot to follow the steps.
Thanks!
