When I run the following script, Coreform Cubit 2023.11 crashes without an error.
create sphere radius 100
mesh surface all
Volume 1 copy move z 210
mesh surface all
Hi @ksugahar,
thanks for reporting this! We will take a look.
One quick comment to get you unstuck, it’s unnecessary to mesh surface all for spheres if you then plan to mesh vol all. Just do:
I want the same surface mesh on two spheres.
Finally, I changed it as follows:
webcut volume 1 with plane zplane offset -0.4
volume 1 2 copy move z 2.1 nomesh
create sphere radius 0.2
subtract volume 5 from volume 1 imprint
create sphere radius 0.3
volume 7 move z 2.1
subtract volume 7 from volume 3 imprint
volume all scheme tet
mesh volume 1 2
copy mesh surface 3 onto surface 7 source curve 1 source vertex 1 target curve 3 target vertex 3
copy mesh surface 5 onto surface 8 source curve 1 source vertex 1 target curve 3 target vertex 3
compress
I’m glad you found a work-around. I was able to replicate the problem.
Here is what is happening in your first case:
An\ alternative to your mesh using hexes involves splitting and coring the spheres so that they are hex-meshable. I just copied the meshed regions that you wanted exactly the same. It was easier than dealing with scheme copy.
volume 7 move z 2.1
webcut volume all with cylinder radius 0.1 axis z
webcut volume 2 4 6 8 plane xplane
vol all size .05
mesh volume with z_coord < 1.0
delete volume 4, 10, 16
Volume 15 2 9 copy move z 2.1
imprint volume with z_coord > 1.1
merge volume with z_coord > 1.1
mesh vol with not is_meshed
Coreform Cubit Consulting
karl@coremesh.co
