Coreform Cubit Version: =
Coreform Cubit 2022.4
Platform:
Manjaro 21.2.6 XFCE x86_64 Linux 5.15.41-1-MANJARO
Issue
I can launch and set license, after close the window.
launch the coreform_cubit gives the error below:
Fontconfig warning: “/usr/share/fontconfig/conf.avail/05-reset-dirs-sample.conf”, line 6: unknown element “reset-dirs”
ERROR: Error loading /opt/Coreform-Cubit-2022.4/bin/./python3/libcubit_python3.so:
ERROR: segmentation fault (core dumped)
Debug info:
execve("/usr/bin/coreform_cubit", [“coreform_cubit”], 0x7fff1e507200 /* 80 vars /) = 0
brk(NULL) = 0xaba000
arch_prctl(0x3001 / ARCH_??? */, 0x7ffc3d626410) = -1 EINVAL (Invalid parameters)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f3bea73e000
readlink("/proc/self/exe", “/opt/Coreform-Cubit-2022.4/bin/c”…, 4096) = 45
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./glibc-hwcaps/x86-64-v3/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./glibc-hwcaps/x86-64-v3”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./glibc-hwcaps/x86-64-v2/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./glibc-hwcaps/x86-64-v2”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls/haswell/x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls/haswell/x86_64”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls/haswell/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls/haswell”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls/x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls/x86_64”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./tls”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./haswell/x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./haswell/x86_64”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./haswell/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./haswell”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./x86_64/libclarogui.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./x86_64”, 0x7ffc3d625630, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./libclarogui.so”, O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\305\2\0\0\0\0\0”…, 832) = 832
pread64(3, “\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0”…, 896, 64) = 896
pread64(3, “\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\3577^\30\225\350\277\354(\203\215X\216z}\226”…, 36, 870560) = 36
newfstatat(3, “”, {st_mode=S_IFREG|0755, st_size=1213952, …}, AT_EMPTY_PATH) = 0
mmap(NULL, 1213952, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f3bea615000
mprotect(0x7f3bea63e000, 991232, PROT_NONE) = 0
mmap(0x7f3bea63e000, 348160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x29000) = 0x7f3bea63e000
mmap(0x7f3bea693000, 262144, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7e000) = 0x7f3bea693000
mmap(0x7f3bea6d4000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xbe000) = 0x7f3bea6d4000
mmap(0x7f3bea6db000, 61440, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc6000) = 0x7f3bea6db000
mmap(0x7f3bea6ea000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd5000) = 0x7f3bea6ea000
mmap(0x7f3bea6f8000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe3000) = 0x7f3bea6f8000
mmap(0x7f3bea706000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf1000) = 0x7f3bea706000
mmap(0x7f3bea714000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xff000) = 0x7f3bea714000
mmap(0x7f3bea722000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10d000) = 0x7f3bea722000
mmap(0x7f3bea730000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11b000) = 0x7f3bea730000
close(3) = 0
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/./libpthread.so.0”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/…/lib/glibc-hwcaps/x86-64-v3/libpthread.so.0”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/…/lib/glibc-hwcaps/x86-64-v3”, 0x7ffc3d625610, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/…/lib/glibc-hwcaps/x86-64-v2/libpthread.so.0”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/…/lib/glibc-hwcaps/x86-64-v2”, 0x7ffc3d625610, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/…/lib/tls/haswell/x86_64/libpthread.so.0”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, “/opt/Coreform-Cubit-2022.4/bin/…/lib/tls/haswell/x86_64”, 0x7ffc3d625610, 0) = -1 ENOENT (No such file or directory)
mmap(NULL, 215599, PROT_READ, MAP_PRIVATE, 17, 0) = 0x7f3bdc72b000
close(17) = 0
openat(AT_FDCWD, “/usr/lib/libcrypt.so.1”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
munmap(0x7f3bdc72b000, 215599) = 0
munmap(0x7f3bdcaa9000, 33360) = 0
munmap(0x7f3bac081000, 3653808) = 0
write(3, “[2022-05-30 19:25:01.130] [app_l”…, 198) = 198
newfstatat(1, “”, {st_mode=S_IFCHR|0620, st_rdev=makedev(0x88, 0x1), …}, AT_EMPTY_PATH) = 0
write(1, “ERROR: Error loading /opt/Corefo”…, 83) = 83
write(1, “ERROR: \n”, 8) = 8
— SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x31f} —
+++ killed by SIGSEGV (core dumped) +++
Thank you.
My installation steps are:
- sudo debtap Coreform-Cubit-2022.4+26186_e1209cf7-Lin64.deb
- chmod 777 coreform-cubit-2022.4-2022.4-1-x86_64.pkg.tar.zst
- sudo pacman -U coreform-cubit-2022.4-2022.4-1-x86_64.pkg.tar.zst
