Coreform Cubit 2022.4
Fedora Core 36
I’m fairly sure I’ve found a bug regarding the ‘side’ command, so one can use the command side so for example
Cubit>side 1 add surf 1
Added Surface 7 to sideset 1
When renaming a sideset the side command is not expanded/alias with sideset so,
Cubit>side 1 name "bob"
ERROR: Syntax error in "side" command.
At least one line ID must be included in command.
Where as
Cubit>sideset 1 name "bob"
Finished Command: sideset 1 name "bob"
Is fine.
I presume this is a bug since, I can’t think if any case where you would want it to be inconsistent?
