Hi
The new Coreform Cb segfaults immediately after launch on FC33
[2021-02-07 11:24:47.287] [info] RLM session initialized
Supervisor::Impl::load_plugins: Loaded component: libcubitcomp.ccl
Supervisor::Impl::load_plugins: Loaded component: libcubitcompgui.ccg
Fontconfig warning: "/usr/share/fontconfig/conf.avail/05-reset-dirs-sample.conf", line 6: unknown element "reset-dirs"
Segmentation fault (core dumped)
I do get the Coreform Cubit splash screen if it helps.
Running through gdb on the core dump gives me this
#1 0x0000000034880228 in ?? () from /opt/Coreform-Cubit-2020.2/bin/libcubiti19.so
#2 0x0000000000000002 in ?? ()
#3 0x000000005322ef28 in ?? ()
#4 0x0000000052e80fd8 in ?? ()
#5 0x0000000052e9b068 in ?? ()
#6 0x0000000052e80f00 in ?? ()
#7 0x0000000006da95d8 in std::string::_Rep::_S_empty_rep_storage ()
from /lib64/libstdc++.so.6
#8 0x0000000007258900 in vtable for CubitOperationEvent ()
from /opt/Coreform-Cubit-2020.2/bin/libcubit_util.so
#9 0x000000000000001a in ?? ()
#10 0x00000000531b7e50 in ?? ()
#11 0x0000000033cbcbb0 in ?? ()
#12 0x000000005148a190 in ?? ()
#13 0x0000001ffeffe190 in ?? ()
#14 0x00000000511f8f50 in ?? ()
#15 0x00000000511cc160 in ?? ()
#16 0x00000000067b6f90 in ?? () from /opt/Coreform-Cubit-2020.2/bin/libvtkCommonCore-8.2.so.1
#17 <signal handler called>
#18 0x0000000000000000 in ?? ()
#19 0x000000003d45bfb6 in ?? ()
--Type <RET> for more, q to quit, c to continue without paging--
from /opt/Coreform-Cubit-2020.2/bin/libvtkRenderingOpenGL2-8.2.so.1
#20 0x00000000511cc160 in ?? ()
#21 0x000000003d449e0c in ?? ()
#22 0x00000000511cc160 in ?? ()
#23 0x000000005148a190 in ?? ()
#24 0x00000000511cc160 in ?? ()
#25 0x000000003d44794c in ?? ()
#26 0x00000000511cc160 in ?? ()
#27 0x000000003d446da5 in ?? ()
#28 0x0000000000000000 in ?? ()
Valgrind gives me more, but Im not sure how much help it will be, let me know if I can include it for you. Running with nographics seems to suggest that it maybe graphics related, there are driver arguments but I’ve no idea of what options are allowed
Andy
