Command Line Setup
I am a junior admin on a HPC cluster and was asked to set up this software within a container for a researcher. However all the documentation I have found is for a gui based environment. Is it even possible to set up and use this software via command line? Any help is welcome! For reference I currently have it in an Ubuntu container.
Cheers.
If you run Cubit like this: ./coreform_cubit -nographics -prompt Cubit you’ll load into an interactive command-line prompt. You can also run Cubit in batch mode like this: ./coreform_cubit -nographics -batch <journal_file.jou>. That will take the journal file that’s passed in and run all the commands in it, then exit Cubit.
Installation for GUI mode vs command line mode is identical.
Thank you, this worked perfectly!
