Can't find Product Key
I am using an educational Cubit Coreform license, and I am trying to run sculpt via the console, but get the following error.
In an attempt to resolve this error, I installed RLM via LINK. However, to set up RLM, I need a product key, and I am unable to find it.
I followed the instructions detailed at LINK, but my product key was nowhere to be found. Specifically, this is what I see when I go to the license page.
Do you know what I can do to find the product key?
Thank you very much.
What version of Coreform Cubit are you using?
The newest one. I think 2022 April?
A Cubit Learn license does not use RLM, so you do not have a product key that you can use. RLM is only used for paid licenses.
Can you include the full output of sculpt please? You should still be able to use sculpt from the command line with Cubit Learn.
I see. This is how I tried to run sculpt from the command line.
The output is attached below. Thanks for helping out, by the way.
emphasized text
I think the RLM output is actually a false error here. It’s printing the RLM errors but then falling back to Cubit Learn licensing. You wouldn’t get to “Could not read input file” if the licensing failed. The actual error is that sculpt can’t find the input file you’re trying to pass it.
That makes a lot of sense. Thank you very much :slight_smile:
