Hey Scot,
Thanks for your help! I tried your commands and the output is below.
Your commands did open up a CUBIT window and it stayed there. However, after I closed it and try launching CUBIT again from clicking on the icon, again the initialization window just flashed for a second and disappeared, I am receiving the same system error as mentioned in my original post.
Moreover, I am unable to import the python package. I will be interested in using CUBIT just from python scripts.
Thanks!
[2022-05-09 09:15:25.036] [app_logger] [info] Using gui
[2022-05-09 09:15:25.611] [app_logger] [trace] rlm_dir: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/licenses:/Users/axelwang/Library/Preferences/Coreform/licenses
usb support disabled
[2022-05-09 09:15:25.611] [app_logger] [debug] /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/licenses:/Users/axelwang/Library/Preferences/Coreform/licenses
[2022-05-09 09:15:25.628] [app_logger] [debug] RLM initialized
[2022-05-09 09:15:25.628] [app_logger] [info] RLM session initialized
[2022-05-09 09:15:25.628] [app_logger] [debug] RLM Diagnostics at 05/09/2022 09:15
RLM version: 14.1BL3
RLM platform: x64_m1
OS version: 19.6.0
ISV name: csimsoft
Hostname: SE3-C02VJ0Q7HTDF
User: axelwang
Working directory: /Users/axelwang/Desktop
Environment:
RLM_CONNECT_TIMEOUT=<not set>
RLM_LICENSE=<not set>
RLM_NO_UNLIMIT=<not set>
RLM_PATH_RANDOMIZE=<not set>
RLM_PROJECT=<not set>
RLM_QUEUE=<not set>
RLM_ROAM=<not set>
RLMSTAT=<not set>
HTTP_PROXY=<not set>
csimsoft_LICENSE=<not set>
RLM hostid list:
0 uuid=747ab531-182c51b8-bb083273-5bc933fa 8c859054f273 823f7c449c01 823f7c449c00 823f7c449c05 823f7c449c04 ip=10.30.65.10
License files:
/Users/axelwang/Library/Preferences/Coreform/licenses/56A6165-6F9954-422941-1A33A2-21B43D1.lic
rlm_init() parameters:
1: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/licenses:/Users/axelwang/Library/Preferences/Coreform/licenses
2: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/Coreform-Cubit-2022.4
3:
<none>
In license file /Users/axelwang/Library/Preferences/Coreform/licenses/56A6165-6F9954-422941-1A33A2-21B43D1.lic
(no server)
trelis_fea v2023.5 OK
trelis_cfd v2023.5 OK
trelis v2023.5 OK
trelis_core v2023.5 OK
cf_gcls v2023.5 OK
trelis_sculpt v2023.5 OK
Roaming Licenses:
<none>
[2022-05-09 09:15:27.631] [app_logger] [debug] Pushing fid: 1, trelis
[2022-05-09 09:15:27.631] [app_logger] [debug] Pushing fid: 4, trelis_core
[2022-05-09 09:15:27.631] [app_logger] [debug] Pushing fid: 2, trelis_fea
[2022-05-09 09:15:27.631] [app_logger] [debug] Pushing fid: 3, trelis_cfd
[2022-05-09 09:15:27.631] [app_logger] [debug] Pushing fid: 13, trelis_sculpt
[2022-05-09 09:15:27.631] [app_logger] [debug] Feature trelis status: 0
[2022-05-09 09:15:27.632] [app_logger] [debug] Feature trelis_core status: 0
[2022-05-09 09:15:27.632] [app_logger] [debug] Feature trelis_fea status: 0
[2022-05-09 09:15:27.632] [app_logger] [debug] Feature trelis_cfd status: 0
[2022-05-09 09:15:27.632] [app_logger] [debug] Feature trelis_sculpt status: 0
[2022-05-09 09:15:27.632] [app_logger] [debug] has_feature: feature_id = 1
[2022-05-09 09:15:27.632] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:27.632] [app_logger] [debug] has_feature: feature_id = 4
[2022-05-09 09:15:27.632] [app_logger] [debug] has_feature: feature_id = 2
[2022-05-09 09:15:27.632] [app_logger] [info] Logged in
[2022-05-09 09:15:27.632] [app_logger] [info] Set OPAL_PREFIX to /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/mpi
[2022-05-09 09:15:27.633] [app_logger] [info] Set OPAL_LIBDIR to /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/mpi/lib
[2022-05-09 09:15:27.633] [app_logger] [info] Set OPAL_BINDIR to /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/mpi/bin
[2022-05-09 09:15:27.633] [app_logger] [info] Python version 0 selected
[2022-05-09 09:15:27.634] [app_logger] [info] Looking for Python
[2022-05-09 09:15:27.636] [app_logger] [debug] CubitDynamicLoader: load_library_sys: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/python3/libcubit_python3.so
[2022-05-09 09:15:27.643] [app_logger] [info] Python not already initialized, initializing
[2022-05-09 09:15:27.643] [app_logger] [info] Application directory is /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS
[2022-05-09 09:15:27.643] [app_logger] [info] python_lib path: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/python3/Python.framework/Versions/3.9/Python
[2022-05-09 09:15:27.643] [app_logger] [info] python_dir: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/python3/Python.framework/Versions/3.9
[2022-05-09 09:15:27.643] [app_logger] [info] Found embedded python
[2022-05-09 09:15:27.699] [app_logger] [info] Version 3 interpreter found
[2022-05-09 09:15:27.699] [app_logger] [info] Cubit python initialized
[2022-05-09 09:15:27.699] [app_logger] [info] Starting broker
[2022-05-09 09:15:27.699] [app_logger] [info] Passing control to MachineControl
[2022-05-09 09:15:27.715] [app_logger] [debug] Dealer::restore_settings: loading QSettings from : /Users/axelwang/.config/Coreform/Cubit.ini
[2022-05-09 09:15:27.715] [app_logger] [debug] Dealer::restore_settings: no Python addons
[2022-05-09 09:15:27.715] [app_logger] [debug] Supervisor::Impl::load_plugins: Loading plugins from QCoreApplication::applicationDirPath : /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS
[2022-05-09 09:15:27.715] [app_logger] [info] Loading plugin from path /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS
[2022-05-09 09:15:27.718] [app_logger] [info] Attempting to load: libcfplugincomp.ccl
[2022-05-09 09:15:27.718] [app_logger] [debug] ClaroPlugin::load: loading: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcfplugincomp.ccl
[2022-05-09 09:15:29.741] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugincomp.ccl from directory: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS
[2022-05-09 09:15:29.741] [app_logger] [debug] Registering plugin components
[2022-05-09 09:15:29.741] [app_logger] [info] Attempting to load: libcfplugingui.ccg
[2022-05-09 09:15:29.741] [app_logger] [debug] ClaroPlugin::load: loading: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcfplugingui.ccg
[2022-05-09 09:15:29.792] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcfplugingui.ccg from directory: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS
[2022-05-09 09:15:29.792] [app_logger] [debug] Registering plugin components
[2022-05-09 09:15:29.792] [app_logger] [info] Attempting to load: libcoreformcae.ccg
[2022-05-09 09:15:29.792] [app_logger] [debug] ClaroPlugin::load: loading: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcoreformcae.ccg
[2022-05-09 09:15:29.877] [app_logger] [error] dlopen error: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcoreformcae.ccg dlopen(/Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcoreformcae.ccg, 9): Library not loaded: @rpath/QtWebEngineCore.framework/Versions/5/QtWebEngineCore
Referenced from: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcoreformcae.ccg
Reason: image not found
[2022-05-09 09:15:29.877] [app_logger] [error] Error loading component libcoreformcae.ccg:
Error loading component:
libcoreformcae.ccg
[2022-05-09 09:15:29.877] [app_logger] [info] Attempting to load: libcubitcomp.ccl
[2022-05-09 09:15:29.877] [app_logger] [debug] ClaroPlugin::load: loading: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcubitcomp.ccl
[2022-05-09 09:15:29.880] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcomp.ccl from directory: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS
[2022-05-09 09:15:29.880] [app_logger] [debug] Registering plugin components
[2022-05-09 09:15:29.880] [app_logger] [info] Attempting to load: libcubitcompgui.ccg
[2022-05-09 09:15:29.880] [app_logger] [debug] ClaroPlugin::load: loading: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/libcubitcompgui.ccg
[2022-05-09 09:15:30.062] [app_logger] [info] Supervisor::Impl::load_plugins: Loaded component: libcubitcompgui.ccg from directory: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS
[2022-05-09 09:15:30.062] [app_logger] [debug] Registering plugin components
[2022-05-09 09:15:30.562] [app_logger] [debug] Pushing fid: 1, trelis
[2022-05-09 09:15:30.562] [app_logger] [debug] Pushing fid: 4, trelis_core
[2022-05-09 09:15:30.562] [app_logger] [debug] Pushing fid: 2, trelis_fea
[2022-05-09 09:15:30.562] [app_logger] [debug] Pushing fid: 3, trelis_cfd
[2022-05-09 09:15:30.562] [app_logger] [debug] Pushing fid: 13, trelis_sculpt
[2022-05-09 09:15:30.562] [app_logger] [debug] has_feature: feature_id = 1
[2022-05-09 09:15:30.562] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:30.562] [app_logger] [debug] has_feature: feature_id = 4
[2022-05-09 09:15:30.562] [app_logger] [debug] has_feature: feature_id = 2
[2022-05-09 09:15:30.626] [app_logger] [debug] CubitDynamicLoader: load_library_sys: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/plugins/libmaterial_commands.so
[2022-05-09 09:15:30.667] [app_logger] [debug] CubitDynamicLoader: load_library_sys: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/plugins/libcfplugincmd.so
Creating new Workspace session
Initializing LLVM
[2022-05-09 09:15:32.911] [app_logger] [debug] CubitDynamicLoader: load_library_sys: /Applications/Coreform-Cubit-2022.4.app/Contents/MacOS/plugins/libworkspacecmd.so
Loading workspace command plugin
[2022-05-09 09:15:33.062] [app_logger] [debug] has_feature: feature_id = 13
[2022-05-09 09:15:33.062] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.194] [app_logger] [debug] has_feature: feature_id = 2
[2022-05-09 09:15:33.194] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.194] [app_logger] [debug] has_feature: feature_id = 3
[2022-05-09 09:15:33.194] [app_logger] [debug] has_feature: feature_id = 10
[2022-05-09 09:15:33.194] [app_logger] [debug] has_feature: feature_id = 8
[2022-05-09 09:15:33.196] [app_logger] [debug] has_feature: feature_id = 3
[2022-05-09 09:15:33.196] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.201] [app_logger] [debug] has_feature: feature_id = 3
[2022-05-09 09:15:33.201] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.205] [app_logger] [debug] has_feature: feature_id = 2
[2022-05-09 09:15:33.205] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.206] [app_logger] [debug] has_feature: feature_id = 3
[2022-05-09 09:15:33.206] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.224] [app_logger] [debug] has_feature: feature_id = 3
[2022-05-09 09:15:33.224] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.224] [app_logger] [debug] has_feature: feature_id = 2
[2022-05-09 09:15:33.631] [app_logger] [debug] has_feature: feature_id = 2
[2022-05-09 09:15:33.631] [app_logger] [debug] has_feature: feature_data->valid = 0
[2022-05-09 09:15:33.631] [app_logger] [debug] has_feature: feature_id = 3
