Hello cubit expert, I am a beginner to cubit. I now want to divide a two-dimensional entity. Can cubit be implemented ?
Hi @Fisher007,
Can you give a little more information on your problem? Do you want to create a 2D mesh? Do you want to do Boolean operations on a 2D surface?
Below is an example using Cubit’s command language to create and mesh two surfaces. You can paste these commands into the command window or paste them in the journal editor and execute them.
create surface rectangle width 10
create cylinder radius 2 z 2
# Perform a Boolean operation between a sheet body (surface) and a volume
subtract body 2 from body 1
# Divide the sheet body in half
webcut body 1 plane xplane
surface all element type quad
mesh surface all
