Coreform Cubit 2024
windows 10
i am now studying on the simulation of stamping process by “DynaForm”, which uses an Orthogonal style mesh, the main area is quadrilateral mesh, and triangular/quadrilateral mixed mesh on the boundary. and there is chordal deviation control and angle control on the boundary mesh.
i just want to know can coreform cubit generate such style mesh? i want to use coreform cubit to do the mesh.
thanks.
Hi @simxpert,
this mesh style is not supported.
Standard scheme would probably be triprim.
You could achieve something similar by decomposing the geometry into rectangles and triangles.
create surface rectangle width 1 height 1.5 zplane
move surface 1 x 0.5 y 0.75
tweak vertex 2 chamfer radius 0.8
tweak vertex 5 6 fillet radius 1
n = 20
m = 30
for i in range (n):
cubit.cmd(f"webcut body all with plane xplane offset {1/n*i}")
for i in range (m):
cubit.cmd(f"webcut body all with plane yplane offset {1.5/m*i}")
imprint body all
merge body all
block 1 add surface all
surface all size 10
surface_list=cubit.parse_cubit_list("surface","all")
for sid in surface_list:
vertex_list = cubit.get_relatives("surface" , sid, "vertex" )
if len(vertex_list)==3:
cubit.cmd(f"surface {sid} scheme trimesh")
cubit.cmd(f"mesh surface {sid}")
mesh surface all
draw block 1
