I’m working on a pretty nasty CAD model. When I tried to mesh the volume with simple tetmesh I often run into the below error:
Found edge/face intersection: 1 2 with 3 4 5
which, I guess, indicates bad geometry, or a bad mesh size.
But I don’t understand what those numbers stand for, is it node ids, or something else? If I know where the problem happens (on which surfaces, etc.) I can go back and fix it.
Anybody experience this same problem can help me? What are those numbers stand for, and there is a way to locate where the bad geometry is? Thanks a lot!
