Boundary Layer: tiny depth mismatch, meshing the whole thickness of volume
Hi, I’ve been working on meshing a fairly complex geometry and noticed that covering the entire wall thickness with a boundary layer would simplify the process and provide better control over mesh quality. However, the boundary layer tool doesn’t seem well suited for meshing the full thickness of the geometrie. Even if I set the boundary layer depth to match the wall thickness, it doesn’t align perfectly. ( I’m selecting a suitable growth rate by solving an equation derived from the sum of geometric sequence.)
I attached a simplified version of my meshing script and a screenshot of the simplified geometry and mesh. I would appreciate any advice on how to approach this or how to make the boundary layer match the thickness reliably or a pointer to a tool better suited for my aplication (resolving skin effect). I also tried meshing the full geometry with a boundary layer, converting it into a mesh-based geometry, and removing the original solid, but this method often fails on the full geometry, even though a small error in dimentions would be acceptable for me.
Any guidance would be helpful.
journal file content:
#geometry parameters
#{width = 0.02}
#{height = 0.012}
#{wall_thickness = 0.002}
#{length_p1 = 0.175}
#{length_p2 = 0.025}
#create the geometry
create surface rectangle width {width} height {height} zplane
create surface rectangle width {width-wall_thickness2} height {height-wall_thickness2} zplane
sweep surface 1 perpendicular distance {length_p1}
sweep surface 2 perpendicular distance {length_p1-wall_thickness}
create surface rectangle width {width} height {width} yplane
create surface rectangle width {width-wall_thickness2} height {width-wall_thickness2} yplane
move Surface 13 x 0 y {-height/2} z {length_p1-width/2}
move Surface 14 x 0 y {-height/2} z {length_p1-width/2}
sweep surface 13 direction 0 -1 0 distance {length_p2}
sweep surface 14 direction 0 -1 0 distance {length_p2} keep
sweep surface 14 direction 0 1 0 distance {height-wall_thickness}
unite volume 1 3
subtract volume 2 4 5 from volume 1
#mesh parameters
#{layers = 12}
#{first_row_height = 0.00003}
#{growth_rate = 1.2809061443676268}
#{mesh_size = 0.005}
create boundary_layer 1
modify boundary_layer 1 uniform height {first_row_height} growth {growth_rate} layers {layers}
modify boundary_layer 1 add surface 5 volume 1 surface 6 volume 1 surface 1 volume 1 surface 3 volume 1 surface 31 volume 1 surface 18 volume 1
modify boundary_layer 1 continuity on
volume 1 size {mesh_size}
volume 1 scheme tetmesh
mesh volume 1
Applying the boundary layer to fill the entire volume is not the design intent of boundary layers. The boundary layer code is always looking for addition volume after the boundary layer.
Cubit provides a method to apply a bias, but the bias must be applied to a curve. With your simple model there is a way to decompose the volumes into hex-meshable volumes with one command. If you really want wedges, you can still trimesh the surfaces and then mesh the volumes.
Here is an alternative scheme. The steps are
  1. Create the basic shape.
  2. Clean up some extraneous curves and makes sure the bodies know about adjacent surfaces.
  3. Decompose the geometry and delete the vold volume
  4. Apply the bias to a curve and propagate the bias.
  5. Mesh the volumes.
#{width = 0.02}
#{height = 0.012}
create brick x {width} y {height} z {length_p1}
move volume {Id("volume")} z {length_p1/2}
split surface 3 offset curve 6 distance {width}
sweep surface {Id("surface")-1} perpendicular distance {length_p2}
regularize volume 1 # optional
webcut volume 1 offset_tool surface all except 1 7 offset {wall_thickness} loft
delete volume 2
# ensure you will have a conformal mesh
#mesh parameters
#{layers = 12}
# apply the bias to one curve and then propagate the bias to the volumes
curve 109 interval {layers}
curve 109 scheme bias factor {growth_rate} start vertex 68
propagate curve bias vol all
# create an element group with all the volumes
block 1 volume all # create an element group including all the volumes
draw block 1
Hope this is helpful,
Your reply is very helpful and much appreciated!
Thank you!
Ros
