Hi!
I’m having some trouble performing boolean operations with volumes created from STL files. My model consists of three volumes:
In green (Volume 1), a "hollow" body.
In orange (Volume 2), a volume that surrounds and partially enters the hollow body.
A box that surrounds both volumes.
set developer commands on
import stl "mandible.stl" feature_angle 135.00 merge stitch
import stl "tissue.stl" feature_angle 135.00 merge stitch
create brick bounding box Volume all extended percentage 50
export stl "box.stl" volume 3 overwrite
delete volume 3
import stl "box.stl" feature_angle 135.00 merge stitch
compress ids
I created Volume 2 with the idea of performing a boolean difference to fill the interior of Volume 1 and then be able to imprint/merge. For Volume 3, I have to save it and then re-import it since it’s not allowed to operate with “volumes containing geometry from different modeling engines”. subtract volume 1 from volume 2 keep works fine but then, if I try to subtract volume 1 from volume 3 keep I get this error:
ERROR: Tiler error in FacetBoolean: premature end of list.
ERROR: Error: Objects for Booleans must first be classified.
Which may be a hint for debugging. I also tried to subtract both Volume 1 and 2 from Volume 3 but got the same error. At the end, I just need these geometries for meshing with sculpt.
I’m attaching the STL files involved.
Many thanks for your help!
Carlos
files.zip (9.6 MB)
