I am using Coreform Cubit 2020.2 in Windows 10.
I have a question regarding the block command for a 2D mesh. I have a 2D quadratic mesh. I want to put some of the mesh elements into a separate block to be able to specify a different material and etc. when I try the block command with quad as the mesh element type I get an error saying “quad : is not a valid option for a block command please check the command syntax”.
Could you please tell me the correct syntax for the block command for quadratic mesh elements?
Would you mind sharing the specific commands you are using?
Are you able to use QUAD4 as the element type?
Have you tried populating the block from the GUI? I ask because the GUI will provide the exact, valid command syntax. Maybe using the GUI will provide additional insight for you.
The command I use in my python code is : cubit.cmd(“delete block all”) and then cubit.cmd("block 1 quad 1500 1501 "). I tried this command with QUAD4 as well but it did not work.
I actually thought about doing it in GUI to get the related command but I did not know how to do that from the GUI.
