Axisymmetric Mesh
Does Trelis has a way to mesh a geometry with axisymmetric mesh? For example, meshing a cylinder with axisymmetric mesh in which the mesh varies radially but the same about cylinder’s longitudinal axis?
Particularly, I am interested in a quarter model of a smooth blunt notch specimen (see picture in attachment).
I usually look at how the model could be swept and what I need to do to get sweepable volumes. Here is one way:
#Create example model
create Cylinder height 10 radius 2
create torus major radius 2 minor radius 1
webcut body 1 with plane xplane offset 0
webcut body 1 with plane yplane offset 0
del vol 3 4
#Mesh
webcut volume 1 with cylinder radius .5 axis z
refine volume all numsplit 1 bias 1.0 depth 1 smooth
By using a cylinder to cut Volume 1, Volume 1 can be swept using Surfaces 35 37 and Volume 5 can be swept using Surfaces 40 43.
