I am working on meshes at a geological scale (several hundreds of kilometers). I have discovered a very annoying bug when working with big coordinates. For example:
_This is OK:
create surface rectangle width 2000000 height 1000000 yplane
volume 1 move x 1000000 z -500000
webcut body 1 with plane xplane offset 1000000
_This is not OK:
webcut body 1 with plane xplane offset 1010000
-> INFO: Cutting Tool overlaps the original volume, Or cutting plane does not pass through volume.
_This is still not OK:
webcut body 1 with plane xplane offset 1050000
_This is beyond understanding:
webcut body 1 with plane xplane offset 1100000
What strikes me the most is that the following commands work fine…
draw plane xplane offset 1010000
draw plane xplane offset 1050000
draw plane xplane offset 1100000
It is possible to get around by explicitly creating the webcut plane but I wanted to signal that however.
Regards,
Alexis Bottero
