Anisotropic hex mesh refinement
Dear Cubit community,
I am using Coreform-Cubit 2025.8 on Windows. I have three bricks in my geometry, and one of them (the middle one) is very thin. I want to refine two parts of my mesh, but the issue is that the refinement density in the z direction is much higher than in the x and y directions. Is there any way to make the refinement pattern anisotropic? I want to have a higher density of refinement in the x and y directions because in the z direction I already have a high density of nodes. My mesh (after the refinement) looks like this:
And here is the script to reproduce the mesh:
brick x 3000 y 3000 z 500
move Volume 1 z -750 include_merged
webcut volume 1 with plane zplane offset -800
webcut volume 2 with plane zplane offset -820
imprint vol all
volume all size auto factor 5
refine hex 990 969 numsplit 2 bias 1.0 depth 1
mesh vertex all
I very much appreciate any help.
Cheers
Ali
Hey @ali_geo,
I wonder if an approach here could be to first mesh the surface, refine that, and then sweep it in the depth direction. Here’s an example of what I mean:
imprint vol all
# Mesh the top surface
surface 1 size 135
surface 1 scheme map
mesh surface 1
# Refine it in the corners
refine face 1 463  numsplit 2 bias 1.0 depth 1 smooth
# Sweep in the depth direction
volume all size 135
volume all redistribute nodes on
volume all scheme Sweep Vector 0 0 -1 sweep transform translate propagate bias
volume all autosmooth target off
mesh volume 1
mesh volume 2
mesh volume 3
Here’s the resulting hex mesh:
Cheers,
Pat
The approach from @pmarty would be the easiest.
Another one would be to insert new columns, but that’s way more troublesome.
imprint vol all
column open node 685  684 686
Thanks @pmarty for your help. I tried it, and the refined mesh looks more homogeneous now.
@Norbert_Hofbauer Sorry, I did not get your solution. How does the column allow me to refine the hex mesh?
This inserts a new collumn of hexes into the mesh. It’s more or less a refinement in x and y without z direction. But definitely not so handy as using the surface refinement approach.
imprint vol all
column open node 662  620 661
column open node 663  662 664
column open node 684  685 661
column open node 686  685 687
column open node 665  664 666
Thanks a lot @Norbert_Hofbauer , I will try it.
