2022.04: insert version you are using (i.e. 2021.11) Windows: insert platform, incl. version (i.e. Ubuntu 20.04)
Issue
I’m running Cubit example file on examples/CubitLib/ . There is an error while calling CubitInterface::initi(). Exception thrown at 0x00007FFD0EF9C369 (msvcr120.dll) in CubitC++.exe: 0xC0000005: Access violation reading location 0x000000230E970000. Do you have some suggestions how to fix it?
I reinstall Coreform 2022.4, and adding some dynamic link lib, the error message changed to: Exception thrown at 0x00007FFD45BE1470 (vcruntime140.dll) in CubitC++.exe: 0xC0000005: Access violation reading location 0x0000000906FDF1E6. the call stack is attached. vcruntime140CallStack.pdf (12.1 KB)
For others who may read this: The problem was making sure the Cubit bin directory and the bin/acis/code/bin directories were in PATH at runtime, as well as building in Release mode to make sure the Windows C runtimes matched.
