I need to make a full 3D variant of the axisymmetric plate with a hole. I’ve made it most of the way there, but am having some issues meshing the volume. My first idea was to create the volume with the hole, then mesh the hole and grade the mesh towards the opposite surfaces.
I was able to mesh all 6 surfaces as well as the surface of the hole in this and other manners. I then tried meshing the volume using either scheme auto, or scheme sweep, where I pick a couple surfaces to sweep between. However, neither of those options seems to work.
Thus, my questions are:
- How can I mesh the volume from the mesh of the surfaces?
- Is this the best way to go about this?
Here is the journal file:
/Applications/Cubit-13.1/Cubit.app/Contents/MacOS/cubitx
Cubit Version 13.1
Cubit Build 47305
Revised 2011-12-16 15:55:34 -0700 (Fri, 16 Dec 2011)
Running 06/24/2012 07:45:38 PM
Command Options:
-warning = On
-information = On
create brick x 20 y 20 z 20
create sphere radius 2
body 2 move -10 -10 10
subtract 2 from 1
surface 10 scheme pave
surface 9 scheme pave
surface 11 scheme pave
curve 13 scheme equal
curve 1 2 scheme equal
curve 1 2 size 2
curve 13 size 0.4
surface 10 sizing function type bias start curve 13 finish curve 1 2
mesh surface 10
curve 7 11 scheme equal
curve 14 scheme equal
curve 7 11 size 2
curve 14 size 0.4
surface 9 sizing function type bias start curve 14 finish curve 7 11
mesh surface 9
curve 15 scheme equal
curve 6 10 scheme equal
curve 6 10 size 2
curve 15 size 0.4
surface 11 sizing function type bias start curve 15 finish curve 6 10
mesh surface 11
surface 2 5 6 scheme pave
surface 2 5 6 size 2
mesh surface 2 5 6
surface 8 scheme pave
surface 8 size 0.4
mesh surface 8
volume 1 redistribute nodes on
volume 1 scheme sweep surface 10 surface 2
mesh volume 1
