3D brick respecting internal curves
I want to create a 3D mesh of a brick that respects a curve (which intersects the surface as well) internal to the brick, while at the same time controlling the mesh size around the curve and the extremities of the brick. In addition, I want to group the nodes along the line into a nodeset so that I can easily assign a boundary condition in the modelling software I am using.
I have tried using the respect command, but it doesn’t seem to be working as I want it to. I’ve attached a journal file of what I have done so far.
Thank you
blast_3d_lines_simple.jou (310 Bytes)
YOu might try the argument “respect edge in curve 13”. Here is the command:
vol 1 tetmesh respect edge in curve 13
