Hey All !
Thanks to @jshimwell for the tutorial on how to containerize Trelis.
We had problems with the graphical interface when running an old Trelis (Trelis-16.5.4) on a recent Fedora OS (FedoraCore 38). Without the GUI / via the python interface it worked as expected. Curiously, the even older Trelis-15.1 runs (with GUI) without any problems at all.
The error messages we got were related to “QOPENGLWidget” and “QXcbConnection”.
We decided to setup a singularity container and run Trelis-16.5.4 inside that container.
Our approach is based on the one posted above with some tweaks.
We install Trelis inside the container at the location /group/programs64/
The recipe we used to create the singularity container: centos7-trelis.recipe
# to build use: singularity build --sandbox ./centos7-trelis.ssb ./centos7-trelis.recipe
# to run: singularity run /path/to/centos7-trelis.ssb
BootStrap: docker
%labels
Maintainer name@group.com
%setup
mkdir -p ${SINGULARITY_ROOTFS}/group
%help
A baseline container for Trelis on CentOS 7
%environment
LC_ALL=C
LD_LIBRARY_PATH=/usr/local/lib64:/usr/local/lib:/usr/lib64:/usr/lib:/lib64:/lib
TZ='Europe/Berlin'
alias ll='ls -l'
export LC_ALL LD_LIBRARY_PATH TZ
%post
yum update -y
# Install basic package (such as editor)
yum install -y wget \
xz-utils \
cmake \
vim \
less \
curl
# Necessary libs
yum install -y mesa-libGL
yum install -y mesa-libGLU
yum install -y gtk2
yum install -y GConf2
yum install -y alsa-lib
yum install -y libSM
yum install -y libXt
yum install -y libXmu
yum install -y tcp_wrappers-libs
yum install -y PackageKit-gtk3-module
yum install -y libcanberra-gtk2
# install dependencies
yum install -y libX11
yum install -y xcb-util-wm
yum install -y xcb-util-image
yum install -y xcb-util-keysyms
yum install -y xcb-util-renderutil
yum install -y libxkbcommon-x11
yum install -y libglvnd-opengl
# install cubit utilizing the rpm package from the coreform website
rpm -i "https://f002.backblazeb2.com/file/cubit-downloads/Coreform-Cubit/Releases/Linux/Trelis-16.5.4-Lin64.rpm" --prefix=/group/programs64/Trelis-16.5.4/
# setup license file (we use a floating license, hosted on the server hostname.domain.com, accessible via port 5051)
echo -e "HOST hostname.domain.com ANY 5051\nISV csimsoft\n" >> /group/programs64/Trelis-16.5.4/bin/licenses/remote.lic
# when the singularity container is "run" the following runscript is executed (inside the container)
%runscript
/group/programs64/Trelis-16.5.4/bin/trelis
Further notes:
- you may need allow the singularity container to connect to X:
xhost + - we used singularity-ce-4.0.0 to build and run the container: Quick Start — SingularityCE User Guide 4.0 documentation
- probably not all the libraries listed above are necessary
- you probably need to adjust the recipe above to meet your needs
Hopefully this is helpful to someone struggling with an old Trelis or Cubit version.
Best,
Lukas
