I’m working on a story for the Advanced Scientific Computing (ASC) program. I’d like to talk about the compute resources required to do the global nullspace problem vs the U-Spline enabled local nullspace problems. Does Coreform have any internal documentation related to this?
Would someone at Coreform be able to guesstimate the compute resources required to find a P2-C1 smooth spline on this example mesh?
Essentially, the story I’d like to say would be something like:
Computing the C^1 smoothness constraint on this problem, globally, requires either:
a) A quantum computer
or
b) An exascale supercomputer running for millions of yearsBut using the U-Spline algorithm allows this problem to be solved in less than a second on a single CPU core.
Is there a story here?
