Hi @xsj617603321,
you could take a look at this post from @karl.
I personally didn’t accomplish a command syntax that can use the extended selection from cubit with the sdk yet. If you want a command syntax that obtains a list of entities, you could also use keywords and the value type, it could look like this
std::vector<std::string> ccxResultConvertJobCommand::get_syntax()
std::vector<std::string> syntax_list;
std::string syntax = "ccx ";
syntax.append("result convert job <value:label='job_id',help='<job_id>'> [partial] ");
syntax.append("[block <value:label='block_ids',help='<block_ids>'>...] " );
syntax.append("[nodeset <value:label='nodeset_ids',help='<nodeset_ids>'>...] " );
syntax.append("[sideset <value:label='sideset_ids',help='<sideset_ids>'>...] " );
syntax_list.push_back(syntax);
return syntax_list;
in the execute you could query the values like this
std::vector<int> block_ids;
if (data.find_keyword("BLOCK")){
data.get_values("block_ids", block_ids);
for more examples you could take a look at the commands in my opensource calculix component.
